service vehicle light is stuck on no m.a.s
Old 10-21-2007, 11:19 AM
trever phillips's Avatar
Default service vehicle light is stuck on no m.a.s
What do i do to turn off my light, no m.a.s code.
Old 10-21-2007, 12:08 PM
SPRAYED 01's Avatar
When i went speed density my service vehicle light came on. My tuner said thats just how it is when you go SD.
Old 10-21-2007, 12:19 PM
LS1Tech Sponsor
Slowhawk's Avatar
The service vehicle light only stays on when going SD if the SD tune is not setup correctly.There are certain codes that have to be changed.
Old 10-21-2007, 04:09 PM
qqwqeqwrqwqtq's Avatar
x2
Old 10-21-2007, 07:44 PM
SPRAYED 01's Avatar
Could you fill me in on the proper way and what codes i need to remove.
Thanks
Old 10-21-2007, 11:13 PM
Thanks
Me to I dont like that light on what do yeah have to do?
Old 10-22-2007, 01:50 AM
cablebandit's Avatar
this will get you in the general direction
Going MAFless
When fitting a 2 or 3-bar MAP sensor you must disable the MAF sensor. It is
possible to leave the MAF sensor in place. This will need to be done on the 85mm
MAF as the Intake Temp Sensor is located in the MAF housing. Alternatively, you
could relocate the IAT using on older style IAT sensor. Even with the MAF still in
place, the PCM must be forced to ignore the MAF signal.
To disable the MAF sensor:
Set the Engine Diagnostics->Engine Diagnostics->MAF->Parameters:
• {C2901} MAF High Frequency Fail 1: 1Hz
• {C2902} MAF High Frequency Fail 2: 1Hz
If calibration {C2902} is not available in the operating system that you are
using, then ignore this step.
• {C2903} MAF High Frequency Fail Limit: 1
• {C2907} MAF Test Min Engine Speed: 300 RPM
• {C2908} MAF Test Min Run Time: 0.1 seconds
Set the Engine Diagnostics->Engine DTC processing Enablers:
• P0101 ‘C’ Non Emissions
• P0102 ‘C’ Non Emissions
• P0103 ‘C’ Non Emissions
Set the Engine Diagnostics->Engine DTC MIL Enablers:
• P0101 ‘No MIL’
• P0102 ‘No MIL’
• P0103 ‘No MIL’
When going MAFless and/or boosted on vehicles with Electronic Throttle Control,
you will most likely need to increase {C6101} ETC Predicted Airflow, by significant
amounts to stop the PCM going into reduced power mode.
Set the
Transmission Diagnostics->Transmission DTC Fault Max Pressure Enablers
• P0101 ‘No’
• P0102 ‘No’
• P0103 ‘No’
Set the Transmission Diagnostics->Transmission Failsafe Enablers:
• Set all airflow related enablers to ‘No’ to prevent the transmission from going
into failsafe mode due to the MAF being disabled.
