Anyone use one of these?
http://store.summitracing.com/partde...?part=ATM-5778
Autometers electric wideband.....? Anyone here have one, what are your thoughts on it? Im getting new guages now and figured i need a wideband and ran across this. Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
hmmm thanks, anyone on here use this one? I'll have to check into it to see if it will data log
__________________
Hmmm, that's what I need. I can replace my pretty much useless air/fuel one. Now I just need to check if they make it in cobalt to match the rest of mine. If you find out if it data logs, post up.
awesome! Thanks JM, looks like i'll be picking one up in my phantom series!
__________________
Just have to program the range acceptable and run a micro switch to the TB. Run one side of the micro switch to ground. Then when the circuit closes (Brown wire from the wideband) it will let the wideband know you are at WOT and montior the AFR. If it goes too lean the wideband starts to blink rapidly! Kind of like the way the dynojet widebands work. Only they have a light on the gauge. Hope that hepls.
thanx for your input
sorry for the semi-jack.......but maybe this will be usefull information for
other people aswell.
yep, more info on this wideband the better!
__________________
nice. you mentioned something about a "bell"...is that in the gauge or wired in with the Micro switch etc. that your installing. i like the fact of not taking my eyes off the road but being warned of a lean condition with some type of device.
