S76-S88 or twin 62-1's or GT35R's
Old 10-24-2007, 03:39 PM
67Firebird455's Avatar
Default S76-S88 or twin 62-1's or GT35R's
Difference between those? What do you guys think? Ball bearing is expensive on the 35r, but worth it? Will be 408ci for the 67 bird. Would like to do twins, but will the s76 or s88 (or t88) work fine for my app? Opinions guys?
Old 10-24-2007, 03:46 PM
6 Second Club Moderator
LASTLS1's Avatar
I happen to know where you can get a set of 66's ball bearing with the hot side.
Old 10-24-2007, 03:48 PM
What're you going with next time? Thanks for the offer, have to actually get the TA sold first! =)
Old 10-24-2007, 04:10 PM
LASTLS1's Avatar
I have the same set up with 76's and headers to fit my ls7 heads.
Old 10-24-2007, 04:43 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yes a BB setup is more expensive, so you will need to weigh that out.
How much power are you shooting for though? I never saw this addressed???
Old 10-24-2007, 04:57 PM
Turbo LS1 SS's Avatar
damn i am wondering this SAME question for both single and twins. not to highjack.
im looking for an easy 750 on lower boost for the street, but have the ability to see over 1000whp if needed. that would only be on occasion though. most important thing is good response, low BP, and high power potential on a high flowing 408
i was thinking S85-88 or pt63s
Old 10-24-2007, 06:06 PM
LS1TECH Sponsor
DrTurbo's Avatar
I would say if your going to stay single then an S85 would be perfect. If you want twins the new FI series units are almost complete. A single FI-62S 61.5Xmm will flow 72lbs/min
Compare that to the GT35R which is also a standard S cover and 61.4Xmm and flows 63 lbs/min.
Old 10-24-2007, 06:34 PM
Coal Mining Director
onfire's Avatar
Do you have a compressor map for a F1-62S ?
Old 10-24-2007, 06:43 PM
Psychopjv's Avatar
<--Turbo Ls1 SS
roundabout price on those FI-X turbos?
Old 10-24-2007, 07:09 PM
I have the exact same goal. 700-800rwhp on the street and 950-1000 at the track if needed. High flowing 408 also @ 8:1 so cranking up the boost won't be a huge issue.
Old 10-24-2007, 07:26 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yup....let me see if they have them where I can attach them. That part of the site isn't up yet and the turbos had to be tested and cert. before they could release the info and that is all done now.
Old 10-24-2007, 07:30 PM
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by Psychopjv
<--Turbo Ls1 SS
Around $1250-$1800 retail for the units and the upper end units are ball bearing and are ETT technology units as well.
Old 10-24-2007, 08:01 PM
But what is your honest opinion for my app? Twins or single S85?
Old 10-24-2007, 08:16 PM
LS1TECH Sponsor
DrTurbo's Avatar
If it was my car, I would go single S85. I love a big single and the way they sound, plus overall its cheaper.
Old 10-24-2007, 08:47 PM
I also love the way they sound, but figured twins would spool faster, but hey, the car is 2955lbs with a pontiac 455 in it, it should be about that with the smaller "ls1" and turbo/intercooler. Do I need an s85 or should I go with something a little smaller? I will only need to boost 950-1000whp MAXIMUM... anything more than that is 100% useless to me, I don't have a death wish... well maybe I do. On the street, keep it around 15-18psi and 750-800whp.
Old 10-24-2007, 08:53 PM
LS1TECH Sponsor
DrTurbo's Avatar
If those are you maximum #'s with the 408, then the S80 will do it. We have a customer now running an S80 on a 385 SBC car that has ran 5.7's@127-129 1/8th so it will definitely make the power. And the car spools like a raped ape and weighs 3515.
Old 10-24-2007, 10:05 PM
onfire's Avatar
408 or 455ci? I'd do the s85...same power at less boost = longer head gasket life.
Old 10-24-2007, 10:13 PM
EARTH MOTORS's Avatar
My customer has a 69 camero 408 4l80e small cam pte 61 twins .58 exaust and the small covers?? needs S covers it backlashs real bad when it starts to spin on [street tires] at any speed it spools real fast is real streetable 14psi=700RWHP 18psi=900RWHP just a compairison LSX shoot out I blew a head gasket bad boost spike boostcontroler problem [operator errr]me it made 870rwhp before 5000rpm there jv
Old 10-24-2007, 11:06 PM
im thinking S85 for me.
what would be the downfall of stepping up to an S88 considering the same goals?
Old 10-25-2007, 12:25 AM
LSInnovations's Avatar
Only downfall is spool rpm...the bigger the later it spools
Quick Reply: S76-S88 or twin 62-1's or GT35R's
