Crank Bolt came out
Crank Bolt came out
Crank bolt came loose yesterday and I could take it out by hand.....I have a d1sc w/ 6-rib. Can someone tell me the torque for the bolt or should I just impact it on.....
I am also looking into pinning the crank so if anyone has any pics or anything post em up.......thanks
Tq on the pulley bolt is massive. Use an old bolt to bed the pulley down at about 230 lbs/ft and then fit in a new bolt at 37 lbs/ft plus 180 degrees iirc. Before fitting the new bolt look for a 2-4 mm step appx between the pulley and crank snout.
Boosted.
Boosted.
Buy the pinning kit & an APR crank bolt & use a drop of locktite. I got all that from Bob at EPP & have never had an issue.....other than it taking me 2 hrs to drill the crank shaft.
I use the ARP bolt, no problems, I just use their lube on it no loctite. Nothing wrong with stockers, but I had mine on and off so many times the ARP made more sence. Very key to get the right torque on them, and get them pinned.
Absolutly key your crank.The first build up I did with the D1SC I did not key the crank.That is why i'm running a Iron block now.The pulley spun the crank nose and I had to build a new motor because of my ignorance! Cost$$$
