No one can diag my turbo issue,please help!!!
Old 11-13-2007, 07:03 PM
SPRAYED 01's Avatar
Default No one can diag my turbo issue,please help!!!
Okay here i am again. One month later,alot of money later and still the same problem. Im running the old qmp log single turbo setup. With a 5lb spring everything is great. I put the 14lb spring in and as soon as it hits 10lbs it instantly drops to 0 and strats pulling vacum at wot.
I had it on they dyno for all testing. We took the IC out of loop for a run just to test and it held 14lbs like a champ. So i paid alot of money for a nice big fmic. Get it on the dyno and same exact thing.
Im a technician and have done an insane amount of testing. Ive rulled out the bov and waste gate by rebuilding them and actually putting my hands about the bov on the dyno. Ive felt to see if the wastegate valve is opening also, its not. Ive pressure tested the entire system many times. It does not leak at all. Ive tried a million different tuning ideas, nothing.
You go wot it hits 10lbs really fast and feel insanly fast, then instantly drops to 0psi and starts to pull vacum.
Plese help, i have no more ideas.
Alex
Old 11-13-2007, 07:07 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
so the only time the kit worked the way you wanted it to is when u bypassed the intercooler?
Old 11-13-2007, 07:19 PM
stevieturbo's Avatar
Is your exhaust system blocked, or could there be a problem there.
Or.
What sort of air filter/plumbing system are you using ?
Old 11-13-2007, 07:38 PM
HUNTER02SS's Avatar
What kind of boost controller,or you just using the spring's. I would say it would be your wastegate spring is not holding and opening up allowing the exhaust to exit freely and then that will cause a vacum and open your blowoff valve!
Old 11-13-2007, 07:43 PM
SPRAYED 01's Avatar
the exhuast is not block,im running a cutout and its flowing fine. I held a rod in the top of the wastegate on the dyno so i could feel if the valve was opening and it wasnt. I had my hand over the bov on the dyno and it did not open when the problem happened.
Yes all i did was bypass the ic and it worked perfect for 3 dyno pulls,just really hot air.
Old 11-13-2007, 07:49 PM
ddnspider's Avatar
then either its a horribly inefficient FMIC or something happens when u reattach it thats causing the problem.no screen in there anymore right?
MIGHTYMOUSE's Avatar
sounds like you need to replace the intercooler or at least cut it open and see where the rag is stuck inside it.
qmp kits tend to drop boost reguardless when you turn them up.
move the wastegate to the cross over and dump it to atmosphere. that is the best you can do.
Old 11-13-2007, 07:54 PM
LS1TECH Sponsor
DrTurbo's Avatar
Are you running an air filter??? If so this was happening to a customer of ours with a S88. The filter would collapse under boost and boost would instantly dissappear.
Old 11-13-2007, 08:00 PM
HUNTER02SS's Avatar
If you bypassed the intercooler and it worked,then you have your answere!The intercooler probably has a crack n it. When it build's boost and get's to a certain point then the crack in the intercooler open's up and bleed's off your pressurized air!
Do a pressure check on your intercooler and see!
Old 11-13-2007, 08:34 PM
solobaric's Avatar
Yes, but he said he replaced the intercooler with another one and it still did it.
Old 11-13-2007, 09:21 PM
calongo_SS's Avatar
my buddies car did the same thing, something worth checking.
Old 11-14-2007, 07:17 AM
smokinHawk's Avatar
if there was a boost leak, the engine should reach 0psi and never pull a vacuum at full throttle, as once in full throttle the engine should read 0psi regardless and hopefully on a boosted engine more then 0psi, something funky is happening, like Dr. turbo said about the filter, have you checked that?
Old 11-14-2007, 07:23 AM
HUNTER02SS's Avatar
Kinda like a radiator in a car. If you have a small leak,you won't know until it build's some pressure in the system and then it will leak. Intercooler is the same way.Just an option to check out.That's all!
Old 11-14-2007, 08:24 AM
SPRAYED 01's Avatar
The intercooler is brand new now. Everything has been tested to 40psi and no leaks. Ive ran it with no air filter with the same results. This seems impossible,but it happens everytime like someone is fliping a switch.
Old 11-14-2007, 08:26 AM
SPRAYED 01's Avatar
what would moving the wastegate do? Is 14lbs to much to ask from this kit.
If im on the highway in 4th at 70mph,i give it 1/4 throttle it builds 14lbs and i can hold it there all day if i dont go past 1/4. Once i give it more gas it instantly drops. So its building the boost no problem. It just dissapears.
Old 11-14-2007, 08:37 AM
i suggest selling it all if you aren't going to relocate the wastegate
Old 11-14-2007, 10:02 AM
SPRAYED 01's Avatar
Mightymouse,
Just tring to understand your suggestion of relocating the wastegate. What issues does the kit have with the waste gate by the turbo?
Old 11-14-2007, 10:11 AM
sevanseriesta's Avatar
mm is wise, I would listen to him. He would not steer you wrong
Old 11-14-2007, 11:57 AM
ABeasst's Avatar
where are you taking your reference for the WG? From the intake or turbo? If its from the turbo and you have a crappy intercooler it will have a pressure drop. Also I'd measure the backpressure, if its really bad it can force the gate open.
Old 11-14-2007, 12:11 PM
SPRAYED 01's Avatar
Its referanced off the turbo. Ive even tried taking the referance off all togeter just as a test to see if it would go to max boost. It does the exact same thing.
How can i mease the backpressure?
Quick Reply: No one can diag my turbo issue,please help!!!
