LS4 Turbo, Valve spring & misfire question
I'm hoping you guys can help shed some light on this problem we are having.
I have a 06 GXP with a LS4 turbo making ~450whp at 12psi with Alky injection. The motor is stock and the LS4 motor has LS6 heads but has LS1 Valve springs which are 76lbs I believe.
We are getting misfiring around 4500-5200rpm at WOT, we tried everything, new plugs, coils, smaller gap, bigger gap, cranked the dwell setting for the coils, turn off the Alky etc. etc. we still get the damn P0300 code for random misfire.
I was reading a lot of posts where people mention they are getting misfiring because of the valves prings being too weak however usually only after a cam/rocker change. Do you think this could be our issue just because of the increased boost now making the already pretty weak LS1 valve spring even weaker? Or would someone have a suggestion as to what we can check next?
thank you for your time!
Jay
Jay
Ok, great.
Are LS6 springs recommended or should I jump to a 918? And then I would need retainers etc. because the stock ones wouldn't work right?
I also read up on the Patriot Springs, they seem a good price and come as a kit are these ok?
Where is the recommended place to buy?
I don't want to have to buy new springs when I put a cam and heads etc. on the car. I had never heard of Patriot's before but they seem popular here so that's good.
