What todo with a slow LT1?
Car is in sig, was pondering a STS kit.. see stock cars running 5-7 psi all day long making 4xx I figure i'm at 400 already its only going to get better and my engines built alittle
any suggestions should I go with STS or custom build or what??
http://www.exoticperformanceplus.com...tCar.php?car=7
Check out our '95 Formula with it's internally stock LT1, that runs 11.31-11.32 in the 1/4. This car should be in the 10's shortly without getting into the engine. Bob
ill have to find out what pistons went in exactly they are either TRW or SRP pistons ill look
ts a felpro HC, LE2 Heads, .30 over on the cyc's and the head surface was decked
i imagine compression is around 10-11.. with .30 + felpro HC
