-10 to 3/8 good enough for return?
Old 11-17-2007, 12:47 PM
SSilverSSurfer's Avatar
Default -10 to 3/8 good enough for return?
Or should i use a. -10 to 5/8?
Old 11-17-2007, 01:00 PM
Tiago's Avatar
it is fine. 5/8 would be equivalent to -10.
you don't need same size return as feed.
Old 11-17-2007, 01:11 PM
stevieturbo's Avatar
return for what ?
fuel, oil ?
Old 11-17-2007, 01:18 PM
ok just checking. The elbow I bought is a 3/8 end into the pan and a -10 to the turbo
Old 11-17-2007, 01:25 PM
Tiago's Avatar
I thought you meant fuel
for oil, 1/2" min on the drain. feed can be 1/4 or -4.
Old 11-17-2007, 02:01 PM
lol ok, ill get that fixed then. the feed is taken care of, im using the -4 line that you showed me in that picture. thanks
Old 11-17-2007, 04:14 PM
MIGHTYMOUSE's Avatar
my return line is -6 and it goes to the stock pressure hard tube which is nearly 1/4" ID
Old 11-17-2007, 04:23 PM
DanZ28's Avatar
Is that your fuel line?
I think he meant the oil return from the turbo?
Old 11-17-2007, 04:26 PM
o right...
i dunno what my turbo il return is.. mabey 1/2 npt in the pan
Old 11-17-2007, 09:00 PM
deadmanTA's Avatar
I got a male -10 AN alum weld on bung from summit. $5.95
Old 11-17-2007, 09:53 PM
you have an aftermarket pan? and a part#?
thanks
Old 11-18-2007, 06:06 AM
The pan is aluminium, You can weld on the male thread adaptors.
Although I tried this, and the pan warped like a banana. I ended up bolting in a bulkead adaptor, with a pair of dowty seals on it. Bulkead cut sort on the inside.
Its worked great for me.
Obviously the pan needs to be off the car for this.
Old 11-18-2007, 06:48 PM
you wouldnt happen to have pics of this do you? i guess i can buy an aftermarket pan and have them weld a bung on(someone on here did that for twins)
thanks again
Old 11-18-2007, 07:08 PM
I'm not saying it cant be welded, of course it can. Just mine warped badly. But I also had to cut/re-shape mine, which would have reduced strength too, and made it easier to warp.
A stock F-Body pan would be much stronger.
I'll take a pic tomorrow. But it really is straightforward.
Just bolt a bulkhead adaptor into the side of the pan at high level. I used -8
Although Ive just removed it from the Alu pan, and Im going to try an Autokraft steel pan I bought.
for no other reason than fitment issues. I had to cut a chunk out of the Alu pan to fit my car, and when it warped, I had to machine it flat again. this reduced the flange thickness, and now the rear corner has cracked, by the oilways for the filter. It hasnt leaked yet...but it was a concern.
I could have welded a fitting onto the steel pan, but figured why buy more bits when the BH fitting worked fine and would be free to swap.
Old 11-19-2007, 08:15 PM
deadmanTA's Avatar
Just got mine welded on today. Going to put it back on the motor wed, I don't think it warped any guess I'll find out soon.
Stevieturbo is right, it's the stock alum pan. PT# is SUM-220062 They have all the -AN sizes in male and female. It's with the Summit brand fuel cells in the catalog.
Old 11-19-2007, 08:16 PM
deadmanTA's Avatar
That part # is for the fitting I used.
