How reliable is the stock one way pcv valve?
Old 11-22-2007, 07:40 PM
2002/Black/SS's Avatar
Default How reliable is the stock one way pcv valve?
right now i have the passenger side valve cover connected to a catch can then connected to the intake side of the turbo. AND the stock line from the back of both valve covers is vented. my question is how reliable is the stock one way valve on the line from the back of both valve covers?
i want to use that valve on the line connected to just the passenger side valve cover for pulling blowby out at idle/cruising and connect the stock line from the back of both valve covers to my catch can/intake side of turbo.
here are the pictures:
Old 11-22-2007, 08:04 PM
Drew04GTO's Avatar
You should throw everything from the stock PCV in the trash and get some Krank Vents. I used them on my last 240sx, my friends lightning and a couple cars before the 240. Lightning pulled 20in/hg of vaccum in the crankcase......
Krank Vents
Old 11-23-2007, 10:30 AM
Reject's Avatar
got some pis of that thing installed?
Old 11-23-2007, 02:16 PM
Closed Sponsor Account
Josh@MASPORT's Avatar
Krank Vents
145 bucks for 2 one way valves?
Old 11-24-2007, 01:35 AM
Drew04GTO's Avatar
$145 is kinda expensive but they actually hold vacuum unlike any OEM pcv i've ever seen. Wish I had some pics but this was years and years ago. I can say for sure that these work almost as well as a vacuum pump on an FI setup.
Quick Reply: How reliable is the stock one way pcv valve?
