size and hp use to turn a F-1A compared to D-1SC
Old 12-03-2007, 03:03 PM
BigRich954RR's Avatar
Default size and hp use to turn a F-1A compared to D-1SC
Is the housing size the same. at the same boost level do they both use the same amount of power to turn. F-1a at 8psi and D-1sc at 8psi.
I know the F-1a will push alot more when spun higher.
With both maxed out how much power to spin them.
Old 12-04-2007, 04:34 AM
EPP
EPP's Avatar
The volute diameter of both blowers is the same. The F1A is about .3/8 longer, so they are virtually the same in overall size.
I don't know how much more power the F1A requires to turn it at 8 psi, but this chart will give you an idea of how much more power it requires overall.
http://www.exoticperformanceplus.com....html?item=439 Bob
