Procharger P-1sc question
Old 12-09-2007, 11:16 PM
badass99ss's Avatar
Default Procharger P-1sc question
Why do people bash the p-1sc boost/hp limits when procharger states the max boost out put is 30psi and max hp is 825hp? Im going to be runing the p-1sc kit in hopes to make 500-600rwhp(got it for cheap). For the longest time I was torn between this kit and the D-1sc kit, procharger states 32psi boost limit and 925 max hp for the D-1sc kit. Thats 2psi more boost and 100hp more over the p-1sc. I know its going to vary car to car/set-up to set-up, but looking at the kits side by side on paper there isn't much of a difference. Maybe im missing something along the way, but after all im new to this FI thing. Any thoughts?
Old 12-09-2007, 11:40 PM
EvoWake's Avatar
From what I understand, the P1 is not built to take high boost as well as the D1. In other words, to run 14# boost on a P1 would stress the HU, bearings and all much quicker than 14# on a D1. I'm sure someone here with more experience will chime in soon though!
Old 12-10-2007, 04:29 AM
EPP
EPP's Avatar
Smile
On a 200 cid engine you would see much more boost from a P-1SC than you would from a 346 cid. There is a much wider difference between the two models of blowers than what it looks like, but for what you're looking to see from the blower, the P-1SC will get you there.
As an example, the max boost we saw from a D-1SC on a 402 cid was 16 psi and we got 757 rwhp, and I was shocked we got that much with the D-1SC. Bob
Old 12-10-2007, 08:36 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
On a 346, the most I have seen personally is 14psi. That was with a 7.65/3.4 pulley combo and the intake hat and filter removed. I don't see the P1 making more than 15psi on a 346 in the very best case scenario...
Old 12-10-2007, 08:58 AM
registered user
ScreaminRedZ's Avatar
I think I remember seeing a video where a guy with an LS1 Vette with a built motor (stock displacement) heads/cam and a P-1SC claiming around 713 rwhp. Does that sound like BS?
Old 12-10-2007, 09:44 AM
LS1TECH Sponsor
Joey@Tick's Avatar
We just finished up a heads/cam/P1 Procharger setup on a customer's 2002 SS with a stock bottom end. It made 537rwhp with only 5psi of boost!
You guys can follow the build here: http://www.carolinarides.com/forum/s...ad.php?t=29458
If you're only wanting 500-600rwhp, the P1 kit will be plenty for you.
Old 12-10-2007, 06:25 PM
badass99ss's Avatar
Do you mind giving the info on the cam you used?
Old 12-11-2007, 12:31 AM
Rickys S/C Z28's Avatar
nice man im doing the same build but i have an auto
Quick Reply: Procharger P-1sc question
