Ninetres 370ci ST80 build
Old 12-30-2007, 02:45 PM
ninetres's Avatar
Default Ninetres 370ci ST80 build
So here is the official thread for my 3rd round with the turbo LS1 world. New street killer set-up is as follows:
370ci iron block ~9.2:1 (10-14psi will be used)
Weisco -11cc slugs
Compstar rods
GM crank
All H series coated bearings
AFR225s with mew GM 5-layer gaskets
BIG STENOD reverse split turbo cam
Yella terra rockers
ST80 turbo with race cover and updated oiling (1.1ex)
4" DP to cut-out
91 pump with ALKYCONTROL dual nozzle methanol kit
Rossler TH400 with 3k stall, spooled 9" with 3.25 gears
Thoughts? Opinions? Ideas? Comments.....etc?????
Old 12-30-2007, 03:02 PM
Websy21's Avatar
Looks like allot of fun, should make some nice power thats for sure.
Old 12-30-2007, 03:07 PM
ninetres's Avatar
Eh, the stalled 400 and 9" kinda hide the power, but I just want her to scoot......and not break. I have a bad *** suspension set-up on my car and I haven't had any seat time to dial her in! Damn shortblock spun the mains before 3k miles and only had about 4 or 5 passes on it.
I need this pig to pull tire on the pavement
Old 12-30-2007, 03:12 PM
Websy21's Avatar
Sounds like once she's dialed in it won't be a problem if you hook, what tires you running? Does the 400 got a transbrake? Nice setup, should make some nice times no prob
Old 12-30-2007, 03:15 PM
52172's Avatar
don't worry it will do that for sure
Old 12-30-2007, 03:17 PM
ninetres's Avatar
Yea, the 400 has a brake and a RMVB. I run a 28x10 MT ET drag slick but am thinking about running on the the ET street radials this summer. Won't have to be so worried driving around town on cruise night if there might be some action on the late night
I also have a set of ZR1 wheels for my real street driving. I usually keep junk sumitomo rubber on them because the spool chews them up so fast.....but I might pucker my cheeks for the new MT 315/35 drag radials. It would be fun to wax some people on a true low pro street tire.
Old 12-30-2007, 03:24 PM
Websy21's Avatar
I run the 315 MT's and they are nice, you should try em out.
Old 12-30-2007, 03:28 PM
Dbluegoat's Avatar
whats the updated oiling on the 80?
when do you plan to have her rolling....
Old 12-30-2007, 03:39 PM
ninetres's Avatar
Not sure exactly. I just know I sent mine in about a month ago for the race cover swap, and they said they also ran some new CNC program on it. I guess it helps the oiling and in return helps spool. Not sure how "new" it is, as I have had my ST80 for almost 9 or 10 months I would imagine.
I was shooting for Feburary, but I think March would be more realistic. The pistons should be at my door mid January, and then the assembly will start.
Old 12-30-2007, 03:42 PM
Dbluegoat's Avatar
hmm......I got mine way back early this year too. Weird your cover looks smaller actually than mine, I thought the race cover would be larger.
Sounds like its gonna be a badass setup, looking forward to the videos
Old 12-30-2007, 03:49 PM
BFEGTO's Avatar
sounds like it will be a nice build. with the trans brake it should be a rocket down the track. it will be intersting to see what kinda numbers it puts down.
Old 12-30-2007, 03:57 PM
ninetres's Avatar
I would say that the cover is about the same size. For whatever reason the pic makes it look small. My camera always does weird things.....probably user error lol.
Shooting for 9s on pump gas (with meth of course).....and daily drivable.
Old 12-30-2007, 04:56 PM
LS1Tech Sponsor
Superman09's Avatar
Glad to see your sticking with it Ninetres! Should be even better this time around.... Your doing one thing right though, when it breaks you keep building it bigger and better than before!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 12-30-2007, 04:59 PM
MECHAM's Avatar
which blankie is that? T4 or T5?
Old 12-30-2007, 05:03 PM
cablebandit's Avatar
why did it spin the mains
Old 12-30-2007, 05:24 PM
allthrotle's Avatar
Should be pretty sweet, You gonna run it in Sac this year?
Old 12-30-2007, 06:03 PM
BFEGTO's Avatar
what kind of pump do you use to return the oil back to the engine?
Josh@KY-Turbo's Avatar
Gonna be back bigger and better this time around. Nice.
Old 12-30-2007, 06:24 PM
ninetres's Avatar
T5 blanket. You know I'll be in Sac (and Famoso) this year. My turbo is just a gravity feed to return oil. Most likely, the old motor spun the mains due to improper machine work on the main lines. Search my threads for "My motor is seized", it gets juicy towards the end
Old 12-30-2007, 09:58 PM
B18CYA's Avatar
Should be a bad *** setup.
Mine will be very similar 370/S80/PP317's/9"3.08/th400
Not sure what injector to go with yet, if I can get away with a 70lbs I think it may even get decent gas millage.
If they would have had that ST80 when I bought my S80 I probably would have went that way.
What kind of converter are you going to use?
Quick Reply: Ninetres 370ci ST80 build
