Profec B vs HKS EVC VI
Anyone have any experience with either. I know it's not going on a LS1, but a boost controller is a boost controller. I am trying to decide which one to get. I know one is cheaper, but I'm looking at features here; so price really doesn't matter.
I use the profec B spec II and have setup several others for people. Cheap and works well. The problem is most people are not smart enough to set them up correctly and then blame the controller because they didn't follow the directions. I've seen more people complain about this controller than any other one simply because the end users didn't know what they were doing.
Sadly I need the easiest to use, which maybe the HKS. I am looking at $16k-$20k (at least) if my motor pops. I understand how they work, but I don't really have any margin for trial and error.
i dunno the profec b is pretty easy to use. They are super reliable and pretty cheap.
Honest opinoin though since you have so much money riding on the boost controller, maybe go with a hallman pro manual? simpilest to use, you can adjust from inside the car with attachment, and its pretty cheap.
Good luck, Chris
Good luck, Chris
Figure out what you need from a controller and go from there..
Im thinking about ordering the HKS EVC VI simply because I want the ability to map boost against throttle position.. My problem isn't one for you since you have awd, but I don't want to make full boost in the middle of the turn when Im applying half throttle, especially with a traction limited car.. With the EVC VI, I can map boost against TP & RPM/Speed..
Never used the EVC VI though.
https://ls1tech.com/forums/showthrea...hlight=ams-500
Here is a link to the most accurate and flexible controllers in the world. Winning races and setting records every weekend!
Here is the thing you need to ask yourself. Will you REALLY be using some of the features that the HKS offers? I have seen a ton of DSM guys buy the latest and greatest in EBC technology only to set boost at X psi and never change it.
If you really need some of the features then by all means buy it up, but the more features it coems with the more complicated it will be to use. On the flip side the Profec is very simple to use and hook up, but it does lack some features.
I love my original Profec B in my DSM. Setting it up was super easy and setting my boost for low and high was as easy and turning a **** and watching a boost gauge.
