Boost gauge
Old 01-04-2008, 01:01 PM
Marz's Avatar
Default Boost gauge
So I am about to get done with my F1A and 408 project and time to look into guages I got a Wideband and fuel pressure gauge so far ..Now my question is for the boost gauge should I use Electric or Mechanical....And the good and bad of each thanx
Old 01-04-2008, 02:02 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
mechanical
Old 01-04-2008, 03:14 PM
dixonk's Avatar
I vote mechanical. I have an electric one (cobalt) it doesnt show vacuum only boost. And sometimes I wonder about the accuracy of it.
Old 01-04-2008, 03:23 PM
Mark98SS's Avatar
I also have a Cobalt elec boost gauge. I have it connected to one of the aux inputs on my HPT logger along with the wide band & fuel pressure so I can review that stuff after a run & keep my eyes on the track ahead of me.
Old 01-04-2008, 04:09 PM
sscamaroburn02's Avatar
what is the difference, besides the price, between mechanical and electrical?
Old 01-04-2008, 04:25 PM
cast iron's Avatar
mechanical is purely meachnical, no electronics. it needs a physical vacumn signal - (vacumn line)
electronic uses a transducer to convert vacumn/boost into 0-5v signal, sends it via wires to gauge which usually displays as a #
electronics are nice sometimes as you aren't running a vacumn line through the firewall/cabin
Old 01-04-2008, 04:28 PM
cast iron's Avatar
it would not be to hard to make your own gauge with the help of an oem map sensor suited for your application.
Old 01-04-2008, 05:05 PM
dixonk's Avatar
The gauge I have actually comes with a MAP sensor. You hook the vacuum line to it and then run the electrical lines from it as well. I just question its accuracy mainly because I have a procharger and it will read 3psi revving in neutral.
Old 01-04-2008, 07:14 PM
ALTRDTA's Avatar
I vote Zeitronix lcd electric gauge. They read EGT, AFR, Boost/vacuum, and Lambda. It has one of the faster updates and also has data logging. I currently use one in my daily beater (1st gen dodge neon with an srt swap,) and I love it.
Old 01-04-2008, 08:08 PM
kwiksilverz28's Avatar
I have http://store.summitracing.com/partde...5&autoview=sku Works great!
Old 01-04-2008, 09:40 PM
vette#3's Avatar
Originally Posted by kwiksilverz28
this gauge is a 190.00 gauge ,it is also a full sweep electric , I run a mechanical & have no issues with it ,it cost me about 54.00 it is an autometer Gauge ,looks just like it the one in the pic but mechanichal
Old 01-04-2008, 09:42 PM
02NBMFormula's Avatar
mechanical, its cheaper.
Old 01-04-2008, 09:46 PM
vette#3's Avatar
this is the 54.00 mechanical gauge that works off of vacuum it works just as well as the 190.00 gauge imo part # atm-4603
Old 01-05-2008, 12:56 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Mechanical for sure.
Old 01-05-2008, 12:28 PM
Marz's Avatar
Ya I thought mechanical would be more accurate cause it is a direct line to the gauge just wanted to make sure and ask questions before I order stuff ...I am gonna think about trying to put the gauge in my vent because space is getting tight than guys
Old 01-05-2008, 06:55 PM
_JB_'s Avatar
I would run a mechanical boost gauge.
Old 01-05-2008, 08:41 PM
It does not record peak boost nor warn of over boost for those with adjustable waste gates.... I like it, dammit!
Old 01-06-2008, 12:35 PM
CALL911's Avatar
I vote electrical all the way. The electrical uses a vacuum line just as the mechanical one does, however the electrical ones have been proven to be more accurate (not that the mechanical ones are way off though). I also have an electrical full sweep boost/vacuum gauge and I can tell you it is awesome, not to mention almost a must have for those needing to be warned about boost levels and being able to recall peak boost levels.
The only thing I don't like about mine is that I got the gauge that peaks at 30#'s of boost when I only make 15#'s. I am currently selling my gauge so I can get another electrical one that peaks at 15#'s.
Here's a link to my gauge. In it is a video of the full sweep electrical gauge in action for those who wanted to see how it works compared to the mechanical one.
https://ls1tech.com/forums/non-lsx-parts-sale/838287-auto-meter-electrical-full-sweep-boost-vacuum-gage-fs.html
Old 01-06-2008, 02:24 PM
Closed Sponsor Account
Josh@MASPORT's Avatar
mechanical cobalt vac/20psi gauge here, no problems
Old 01-06-2008, 03:52 PM
fenix999's Avatar
mechanical, dont complicate your life
Quick Reply: Boost gauge
