Turbo Oil drain line size
Old 01-08-2008, 05:10 PM
71chevellels1's Avatar
Default Turbo Oil drain line size
Ive been seeing that most people are running -4 inlet and a -8 or -10 drain. Why do you need such a big drain? Could i run -4 inlet and -4 drain? Thanks
Old 01-08-2008, 05:12 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Feed= Pressure
Drain= Gravity
You want as much flow as you can get, if there is any sort of restriction then you can blow the seals on the turbo due to the pressure buildup.
Old 01-08-2008, 05:13 PM
LS1Tech Sponsor
Superman09's Avatar
no, there is a reason people run such big drain........
Having oil back up due to too small of line will in turn back up and blow the seals in the turbo and cause smoking. Your feed in fed via Oil Pressure so you can a TON of oil flying threw that -4 line, where as the drain just gravity drips so to speak, you need the bigger hose to drain all the oil. Its a necessity and a big key to your setup, i wouldnt run less than -10 an. Hope this helps!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-08-2008, 05:23 PM
otherwhitemeat's Avatar
**** I Got A -12 Out
LS1Tech Sponsor
Superman09's Avatar
better bigger than too small
__________________
Old 01-08-2008, 05:38 PM
barnat's Avatar
Almost same princible as fuel feed line verses the return line,RIGHT?
Old 01-08-2008, 05:41 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
NO, you always run a larger feed than a return with fuel because you are using a large portion of the fuel so only a small percentage will flow back through the return.
Old 01-08-2008, 06:39 PM
DeltaT's Avatar
Also the oil is often frothy with air coming straight out of the turbo or oil-fed blower.
Jim
Old 01-08-2008, 06:44 PM
Closed Sponsor Account
Josh@MASPORT's Avatar
sort of, but the fuel line is pressurized on the feed line and there are no seals to blow out so it can push the fuel to the tank
Old 01-09-2008, 07:38 AM
smokinHawk's Avatar
when i had a 8an drain my car would smoke, also the turbo was a lower. now the turbo is a little higher and has a 10an drain and no smoke.
the bigger the better as it allows the oil to return better.
Quick Reply: Turbo Oil drain line size
