pt88 t4 and 366
Old 01-11-2008, 04:05 PM
cjg454ss's Avatar
Default pt88 t4 and 366
on an auto with 6.0 heads, iron block, 8.5 compression, 90 tb, ls2 intake, through an auto tranny, is 800 rwhp possible? ive done alot of searching with not much luck. mostly 6 speeds came up.
Old 01-11-2008, 04:11 PM
Josh@KY-Turbo's Avatar
Yes it is possible. My previous shop car made over 770rwhp on 15 lbs of boost with a TC76MPS turbo. This was with a TH400 and 9 inch. The PT88 has the potential to make more.
Old 01-11-2008, 04:13 PM
cjg454ss's Avatar
how much would a 76gts make then, im on the4 fence for buying a turbo,. the pt88 looks much larger on the exhaust side(housing) will the 76gts be too restrictive to get the exhaust out?
Old 01-11-2008, 04:30 PM
LS1TECH Sponsor
tt427ls1's Avatar
The 76gts will work also for your setup just fine. I have used the 76gts on one of my kits and a 370 to 750rwhp easy. Just watch the back pressure. Its also what you want down the road. Remember boost is a drug...lol
Old 01-11-2008, 06:17 PM
Joel is correct. It is really about what your goals are and what they will be. A 76mm turbo will hit 750rwhp easy. The PT88 will too, and then some.
Old 01-11-2008, 06:38 PM
otherwhitemeat's Avatar
Just get the pt88 ..its a nice turbo with room to progress....the 76 has too much back pressure issues..
Old 01-12-2008, 08:49 AM
cjg454ss's Avatar
what would a pt88 make on a 366 with some good gas
Old 01-12-2008, 09:32 AM
MIGHTYMOUSE's Avatar
thats all what i have.. all my good info gets deleted from search
if it made 1k w/ a 6 speed its making 950rw or so w/ the auto. Times in sig. 17" drag radial.
Old 01-12-2008, 11:33 AM
ninetres's Avatar
Yes its possible.
Old 01-12-2008, 11:47 AM
nutz'00 Z28's Avatar
I made a little over 800rwhp on 17psi, with a 8.4:1 370", PT88, TH400, 9".
Old 01-12-2008, 01:41 PM
cjg454ss's Avatar
that is some good news
Old 01-12-2008, 01:50 PM
slick1851's Avatar
If 3.0 inline sixes can do it, a LS1 sure can with even better flowing heads and cubes
Old 01-12-2008, 02:56 PM
topend's Avatar
Do u have any exhaust pressure/ intake pressure reading to support your statement about the 76 having too much backpressure???
Old 01-12-2008, 03:21 PM
Websy21's Avatar
Why don't you spot your et goals instead of you hp goals. That pt88 would haul some *** but the tc76 on that motor would too. Depens on how far you want to push it.
Old 01-12-2008, 03:41 PM
cjg454ss's Avatar
it is a little of everything setup, i just want to make 1000 hp on the motor for advertising reasons, anywhere in the 9s would be fine, but really all around here is 1/8 so 6s would be easy to fall into, 5.9s i think would be a tone of work.
Old 01-12-2008, 05:47 PM
my friend has one on has camaro and it had a lot of measured back pressure and from what ive read a lot of other people have had the same problems......I ran a pt88 for a few years and I mawxed out my set-up at that time with about 24 psi and that was good for about 900-950 at the wheels..more could be gained if I tweeked the set-up.
Old 01-12-2008, 06:02 PM
black98ws6ta's Avatar
It will make the power you are wanting it to...no problem. You motor will thank you for choosing the 88 over the 76.
Quick Reply: pt88 t4 and 366
