Super Damper Question!
Old 01-17-2008, 01:01 AM
98BlkFormula's Avatar
Default Super Damper Question!
I have a d1sc kit and have the ati super damper but i think im missing some stuff and have some questions
Ok so there are 3 bolts that hold the pully to the damper
now this is what i want to know if i need or if i can go without
Thank you
Old 01-17-2008, 04:10 AM
EPP
EPP's Avatar
Give us a call today at 260 244-4808 and we can help you out. Bob
Old 01-17-2008, 08:31 AM
rufretic's Avatar
I only had the three you have holding mine on. When I uninstalled it, one of the bolts was broken. When I put it back on, I will see if I can add more support. I was running about 14psi and would like to go up to about 20psi. If you stay under 10psi I bet it would hold just fine but once you start hitting more boost you have to keep that belt nice and tight which adds to the stress on those bolts holding the pulley. Just mho.
Old 01-17-2008, 03:09 PM
Jake@EPP's Avatar
For a proper install of the Hub to balancer, the balancer its self will need drilled out, as well as the hub. The reason for drilling is the balancer is no longer drilled from ATI. We have drilled every balancer with no issues.
Old 01-17-2008, 07:11 PM
Cheatin' Chad's Avatar
Not trying to be a smart *** here but I would like some clarification.
balancer= harmonic damper?
You're referring to the hub and "balancer" as seperate pieces do you mean breaking the ATI piece apart for this? OR are you referrign to he supercharger drive pulley and the ATI damper assembly?
Seems like there is a regional split on what some parts get called and this confuses me at times.
Old 01-17-2008, 07:46 PM
Jake@EPP's Avatar
Its fine, id rather us be on the same page then somewhere else.
The outer ring = balancer
Hub = piece bolted onto balancer that slides onto crank snout.
Old 01-17-2008, 07:50 PM
Thanks I appreciate the clarification.
Old 01-17-2008, 07:56 PM
Jake@EPP's Avatar
I have a folder of pictures for the whole process on this, just need to put them on our site and do a write up. I will post a few pictures in the morning regarding this.
Old 01-18-2008, 12:23 AM
the pics would be nice
Old 01-18-2008, 07:02 AM
rufretic's Avatar
Old 01-18-2008, 08:05 AM
Jake@EPP's Avatar
I'm having issues with the web host at the moment, working to get it resolved at the moment.
Old 01-20-2008, 09:11 AM
SRZ
SRZ's Avatar
Any update Jake? And why does the damper itself clearly say not to drill as it's zero balanced? I'm a similiar situation and if I can do 6 vs 3 bolts I will.
How hard is it to seperate the front piece and back piece of the damper? Thanks!
Old 01-20-2008, 10:29 AM
Jake@EPP's Avatar
The balancer is a bolt together piece. If it was not drill able, then i wonder why they just quit drilling it? I believe they offer to drill it for something like $40 or so if you send it in.
I have yet to see a single balancer failure due to this, no odd vibrations , just nothing.
Here you guys go, http://www.flickr.com/photos/2278422...7603760150987/
Old 01-20-2008, 10:47 AM
TT-TECH Veteran
Inspector12's Avatar
The three bolts thread all the way through to the A/C pulley on the back are you saying doing this is a problem? The other 6-T45's or what ever size I can't remember for sure just hold the outer ring to the hub. The balancer comes with the smaller 3 bolts so I replaced them with the 3/8 bolts that are for the S/C pulley so I just rotated the A/C pulley around to thread the bolts all the way through outer ring and the A/C pulley. Is there a problem with this is that what you are saying?
Old 01-20-2008, 10:54 AM
Jake@EPP's Avatar
The 6 pan bolts are required to hold the shell onto the hub. you will be rotating the AC mounting to the new holes and have the bolts go through them. The old holes are tapped out to 3/8s for the new ATI bolts.
Old 01-23-2008, 06:14 PM
Thank you Jake for the pics but it looks like my ATI pully is different because it only hase 3 holes. it also looks like my balancer has been drilled but i dont think that i need it because from the looks of the pic you only need the 3 extra holes because the ati pully has 6 but my pully only has 3
Old 01-23-2008, 06:43 PM
Jake@EPP's Avatar
Where/when did you buy this?
The current ati procharger pulley is shown in my pictures.
Old 01-23-2008, 07:24 PM
TT-TECH Veteran
I believe that to be the SDCE pulley set up atleast that is what mine looks like.
Old 01-23-2008, 08:39 PM
Jake@EPP's Avatar
If so, you need to either ditch the AC or figure out a reliable way to mount it.
Old 01-23-2008, 09:12 PM
Yes its the SDCE pully. It should mount just like the one in your pic the only thing is that the with the one i have its 3 bolts holding it all together
Quick Reply: Super Damper Question!
