Which rods for 1800hp?
Old 01-21-2008, 04:56 PM
93formto98T/A's Avatar
Default Which rods for 1800hp?
Hey guys, I've got my new build all out on paper and will be starting it in the next few weeks. The powerplant will consist of the warhawk block and heads (427) with a Procharger F3 up front shooting for 1600-1800rwhp. It will be a land speed application and motor will rev to 7500. My question is what rods would work? They would need to be durable as I don't want to be tearing it down often after she's together. It will see limited street use as well. I've talked with several speed shops and engine builders with mixed reveiws on rods. Some say billet, some say stay away from billet cause it's brittle. Then there's the good ole 4340 rods and the newer 300M forged which are by far the most expensive. I haven't heard of a failure of say the eagle rods but don't know if they've ever been pushed that high. Seems to me that it's more in the rod bolt than the rod itself. In that case would say a compstar/eagle rod w/arp3.5 bolts do the trick?
On a side note, would you guys recommend the new felpro gaskets or should I go O ring+copper?
Old 01-21-2008, 05:04 PM
Shawn @ VA Speed's Avatar
I've run billet rods to over 2500hp in small block chevys.I have Lunati billet rods in my own personal twin turbo engine,makes 2500+ and have been using them for 3 years now with no problems.I spin that motor to about 9000.Run copper head gaskets and orings,they hold up good to over 40 psi boost.If you need anything shoot me a pm or call the shop
Thanks
Shawn
Old 01-21-2008, 05:09 PM
KissMySSo1's Avatar
I have never heard of a failure with the eagle rods either. I've talked to eagle about their rods for my 1500hp applictaion and they said the bolts would be the only problem and i would need L19's. Does anyone know of an eagle H-beam rod failure? Or what A 4340 rod can handle?
Old 01-21-2008, 05:18 PM
NA$TY-TA's Avatar
Never heard of one fail.......
I used the above rods with L19 Bolts in my last motor and using them again in the new Motor Shawn from VA Speed is Building me.
1800 HP is going to be a project...
Whats the budget on the build??
$75-100K for the car???
we've used eagles to 1500hp,but 1500 fwhp and 1600-1800 rwhp is a big difference,it's not worth risking 20,000 on a motor to save a couple hundred bucks
Old 01-21-2008, 05:41 PM
6 & 8 Second Club
mrdragster1970's Avatar
Carrillo, with carr bolts. Big HP, 9000+ rpm BBC.
Old 01-21-2008, 05:54 PM
You're right in the ballpark...
Old 01-21-2008, 05:55 PM
Exactly what I'm thinking. I don't mind spendin the coin on the correct component but I don't want to shell out major $$ for something I don't NEED.
Old 01-21-2008, 07:47 PM
speedracer5532's Avatar
Howard ultimate duty billet rod for $750 is an awesome deal and can handle 1800 hp or you could run a Dyer's 300M rod which is good for 2000+ hp.
Old 01-21-2008, 07:51 PM
Tiago's Avatar
I would go with carrillos for that application...
Old 01-21-2008, 08:31 PM
daniel6718's Avatar
id go wit hthe lt1 front clip for land speed record...just sayin
Old 01-21-2008, 09:25 PM
This setup isn't going into an fbody, I sold it this summer. The new setup is a full tube chassis rear engined car.
Old 01-21-2008, 10:53 PM
NA$TY-TA's Avatar
Yeah i know and understand..... i think last time i added it up i was over $50K and thats before the latest and greatest...... and the sad is, it never end.......
Old 01-21-2008, 11:05 PM
GoatChs's Avatar
Oliver or Carrillo.
Old 01-22-2008, 12:40 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
GRP, BME, or Howard's aluminum rods. Proven performer in high HP applications and ultra light.
Old 01-23-2008, 01:53 AM
chuntington101's Avatar
i know a guys that could get you some billiet TI rods if you want???.........
or you could speak to EPP on here. they are uilding a very similar setup or drag racing. think they are going to be pushing 2000bhp+.
cheers
Chris.
Old 01-23-2008, 07:06 PM
cheers
Chris.
Just the sound of Ti rods says major $$$. I think std billets will do. I'm following the EPP build to see what they come out with. Should be pretty impressive.
Old 01-23-2008, 07:10 PM
RAGENZ28's Avatar
Oliver billet or the Carillo's
Old 01-23-2008, 07:14 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
I would not use Aluminum in a land speed application, they are great for absorbing shock but stretch just as easily..
Carillo will engineer you the strongest rod for your application. Have your Builder call the engineering dept and get a spec sheet. they will take care of the rest.
Old 01-23-2008, 07:17 PM
WAHUSKER's Avatar
I thought the Eagle rods were all made with metal from China now? (= weak)
Quick Reply: Which rods for 1800hp?
