Advancing Cam for decreased SCR?
Old 01-28-2008, 11:21 AM
Mr.MartyStone's Avatar
Default Advancing Cam for decreased SCR?
On a 347 LS1 with a 1.32a/r T6 flange 80mm turbo (running 15-17psi pump gas no meth). I'm dropping from 10.3 to around 8.8:1 SCR with my new setup and currently run a 233/239 on 112+0 HR with around .600 lift on both sides. Would it be to my advantage to advance the cam around 4 degrees to makeup for the loss in SCR/DCR and gain a little drivability? I drive the car quite a bit and don't want a dog down low, but on pump 92 and no meth w/ 15 psi or so I don't want to be fighting detonation.
Currently the car has a Th400 w/ 3000 stall, 3.42's and a 28" MT ET street radial. What do you guys think? I know the cam is probably not optimal but will have to do until I go big. Advance it or makeup for it with more timing?
Marty
Old 01-28-2008, 02:53 PM
Sooooo...anyone? Mods feel free to put this in tuning or Internal engine or wherever you deem fit.
Old 01-29-2008, 10:02 AM
Okay I've pretty much made up my mind and am going to run my cam on a 108 ICL (advanced 4 degrees).
Old 01-29-2008, 10:21 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
What were your findings, advancing the cam made more sense then adding more timing? I was curious, but I had nothing to contribute to your original question.
Old 01-29-2008, 11:08 AM
I asked around on several boards and the general consensus was to put it on a 108 ICL. I was wanting to go that way anyway and am going to try it. If it doesn't work I'll just take it back to a 110 or 112 ICL. I think it would have to be an asston of timing to makeup for the drivability of having it still on a 112.
Thanks though PSJ
Quick Reply: Advancing Cam for decreased SCR?
