most power made on stock 6.0l short block
Old 02-03-2008, 01:12 PM
LS1LT1CAM's Avatar
Default most power made on stock 6.0l short block
how much power can i make before breaking
would like to go 8.60s at 3200 lbs
s88 on stock 6.0l short block with l92 heads carbed intake and BS3 and alcohol
Old 02-03-2008, 01:38 PM
Sideways240sx's Avatar
if ur talking about a stock 6.0 iron block, i would guess around upper 5's to low 6's. If you did rods, bolts, and pistons on the stock crank you should be able to hit your goal. If your talking about an ls2 1 guy on here made 700 but it last about 1,000 miles i believe.
Good luck, Chris
Old 02-03-2008, 01:59 PM
LS1LT1CAM's Avatar
Good luck, Chris
stock pistons, good bolts and good bearing in fresh block have stock internals out of other motor and was thinking about using them for a while till I get forged bought and balanced. Get the car together and all the turbo stuff bought then build a good motor
Old 02-03-2008, 02:09 PM
kwiksilverz28's Avatar
If you have the pistons out of the car, get forged. Get rod bolts. Go fast. :-)
Old 02-03-2008, 02:32 PM
Websy21's Avatar
No kidding if you are already at that point why do it twice?
Old 02-03-2008, 08:18 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
hunter02ss is at 1089rwhp on a 6.0 block
Old 02-03-2008, 08:24 PM
HUNTER02SS's Avatar
But I have forged internal's. If it is all apart,forge it. You will be glad you did!
Old 02-03-2008, 08:26 PM
red83's Avatar
oh ****! i thought it just said BLOCK, not shortblock. one two many beers tonight...............damn superbowl!
Old 02-03-2008, 10:32 PM
Websy21's Avatar
Hunter is at what Tell me that was just for a number on the dyno but non the less thats huge especially in a 377
Who says you need 400+ci I already had my 408 forged motor built and its being rebuilt now to a 370. I think it will be allot meaner combo now
Old 02-04-2008, 07:21 AM
HUNTER02SS's Avatar
Nope,not just a dyno run,i am going for some quick ET's this year!
Old 02-05-2008, 06:38 PM
LS1LT1CAM's Avatar
i know that i should put in forged stuff but on limited buget this year and would like to get the car out and woundering what is the most power ever made on stock short block 600+ wrhp possible for race track only car
Old 02-05-2008, 07:11 PM
93formto98T/A's Avatar
Don't you guys remember CASPER (W2Ws car) 6.0L GM block destroked and made what 1800rwhp?!! Of course that's on the extreme end and they extensively modified that block to get there but at the same time just goes to show you can throw just about anything at it. My last build was a TT 6.0L at just 725rwhp DD.
Old 02-05-2008, 09:17 PM
camarols1's Avatar
This is a no brainer.
If the engine is apart there is no reason to reuse the stock stuff.
Make the investment in some quality forged pistons and good h-beam rods.
If you are shooting for 8's you would be wise to spend the extra $$$
on good parts to avoid breaking the stock stuff.
There is no way the stock internals will take that kind of abuse.
Good luck, your goals and setup are very similar to mine!!!!
Old 02-05-2008, 10:55 PM
Grr
Grr's Avatar
i dont think youll have a problem, just dont go ape-**** on the boost. 600-650whp will last you the year as long as your tune is good, and keep the timing conservative. in a 3000lb car that should be good for low low 10s without a whole lot of drama. Then youll at least get a chance to dial in a good base tune and get suspension/driveline sorted out. Hell im in the 600whp area and i dont even have a intercooler, put about8-10k miles on it last year. I run 89-91 octane, 9.5psi and about 10-12 degrees of timing, 11.3:1 AFR and i drive it daily in the summer. stock right down to the valvesprings
Gary
