iron block for boost.....6 bolts per cylinder
i know the LSX block is the one to use, but can a 6.0L iron block be drilled to have extra bolt holes to accomodate ETP 6 bolt heads?
Was going to buy an iron LSX blocked 408ci from Weber but they don't have any LSX iron blocks.
IRON.
what turbo won't have that problem on a 408ci or 427ci?
What Kyle is saying is that the s91 wont make enough boost to push the head gaskets out of an lsx 6 bolt block if done properly.you can def make 1200+ with the s91
the block is 4500 all day long,and just because it's out of your budget doesnt make it a ripoff,its well priced for what it is,and there are alot of people on this board than can and do buy them
What psi would the S91 need on a 408ci to make 1,200 RWHP on race gas?
Who here has the Warhawk and what set-ups are they? Just curious.
Oh, I see, thanks. So if a 101mm was used it would just be harder on the gaskets and it might push the gaskets.
I guess what I mean by rip-off is an LS1/2/6/7 aluminum block handles over 1,000 RWHP on given set-ups....so to pay that price for a Warhawk for absolutely no power gains is crazy. And from what I gather if you want a set-up to make 1,100+ RWHP you need to go iron if you want reliability. So even for the guy with alot of money I don't see the advantage of a Warhawk. But for 99% of the people here, its way too expensive for no power advantage and not much strength difference.
I'm currently starting a build for a member on here using the warhawk block and heads,he is putting an f3 on it and i know EPP is doing a gto with one.
1200 hp with an s91 can be made at about 30psi depending on the heads,cam and compression,yes the factory block will handle 1000hp with no problems,but the lsx block and warhawk take over where the factory block stop,as far as strenth the lsx blocks cylinders may be a little stronger keeping the rings sealed a little better but they will both handle the power with no problems-so it comes down to if you can afford the extra weight of the iron block-i know for myself,i'm going to be using the warhawk block.
How does it become stronger than the regular ones? Is the outer dimensions of the block bigger? Will it bolt rightinto the car using all factory LSx parts?
the casting is alot thicker to start with,lots off added material in areas that are highly stressed on high hp applications,deck surface is much thicker,the sleeves are more robust and made from a much better material than stock,the warhawk block is heavier than a stock alum block but still much lighter than alum.and it will accept most factory accessories
Ok so good 4 1200hp......what about stock the bottom end w 2 gt45's @ 10 psi making 537 hp.....No problems yet,,,But need money so will sell for than I invested and startover agian.....any recs.....I hear the pistons on the lq4 max @ about 550hp.....
Congradulations, you have successfully hijacked the world supply of FI forum threads to ask a stupid question
