snow performance methanol injection stage 1 or 2??
i tried the search, but couldnt find the info i was looking for
i was just wondering if a stage 1 snow kit would be good for my application or should i go with a stage 2, i dont want to dish out the extra 150 bucks if i dont need to
im gonna be running a single t-61 turbo pushing 7-9psi. it will be on my basically stock 01 z28 it will have an air to air intercooler as well
im ready to buy, just need to know what one to get
thanks in advance
-steve
thanks in advance
-steve
stage 1
STAGE 2
i just dont know if i need that for my application, or if its directed towards higher boost and built motor applications..
i called earlier and left a message, but no call back
Originally Posted by forcedinductions
* Snow Performance Stage 1 Meth Injection System Water/methanol injection system with everything needed to start making big HP!
* Includes: 140 psi high volume pump, adjustable boost pressure switch, 2-qt. Reservoir, two nozzles sized to your FWHP and boost levels, Bosch relay, all the electrical parts, fittings, tubing etc. to install - a complete kit made with quality, proven components.
* Huge HP gains for Non-Intercooled vehicles!.
* Larger reservoir's can be ordered. Ask Sales Dept!
* What are the benefits of Water/Methanol injection? Boost Cooler® Benefits (Gasoline):
1. Low cost - where else can you get up to 60HP for $299.
2. More power than other means of detonation control.
3. Efficiency - leaner air fuel ratio can be utilized for normal operation.
4. Greatly increases air charge densities for huge horsepower increases
STAGE 2
* Snow Performance Meth Injection system Includes Stage-1 plus:
* An upgraded 140psi pump for incredible atomization. 220psi in over 500HP applications.
* Variable Controller that varies the quantity injected vs. boost.
* This allows maximum power at all RPM/boost levels as just the right amount is injected at all times.
* Features include adjustments for onset boost level and full quantity boost level. (See Variable Controller in “products” for a full list of benefits).
* Note: The variable controller replaces the boost pressure switch and relay included in the stage-1 kit.
LS1Tech Sponsor
its just the features in the kit. I own a stage 2, thats what i would get. IIRC, it has a bigger pump and the progressive controller, etc. Stage 2 is what you want. Hope this helps!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
damn, i was hoping i could get away with stage 1 lol.. but if its what i need, and the best choice then so be it.. i knew going into this project it was gonna cost some jack, so no big suprise
Alright, now that I know the difference I have the stage 2 as well. I'm not sure the stage 2 will be anything really over the stage 1 for the original poster. The stage two has the 2nd nozzle for higher boost applications, and then the controller box to progressivly spray more meth as the boost increases. Probably not much to have a spread over when you are only talking 7-9 psi.
Of coarse none of this matters anyways since he already bought the stage 2
FWIW, here's my controller and my settings. The first hit of meth comes on at like 5#'s, and then the next hit comes in at 10#'s.
