diamond or mahle pistons
I'm personally running PROBE blower pistons and to tell everyone the truth there has never been a back to back study or test regarding piston life under exteme FI conditions. Given that matter buy almost any forged piston and you can't go wrong. When was the last time anyone has ever heard of an aftermarket forged piston failure that was not caused by detonation or oil starvation???? Put that in your pipe and smoke it
Mahle's current offering are 4032. This alloy is fine for moderate power levels Ie sub 800hp crankshaft with a very good tuneup. They have some 2618 pistons comming out. I would go with diamond if you are serious about HP.
I would not use 4030 pistons for an FI application.
A vendor sold me on Mahle 4030 alloy pistons as 'stronger than Diamond pistons', they failed on an easy drive home from the motor install. The top ring slot is close to the top of the piston, and valve relief cut ends up very close to the ring slot with nearly 1/16" material between the surfaces. The Mahles don't have much quench area, but for a narrow flat ledge at the edge. The 4030 alloy (~14% silicon) is close to stock brittle hypertech alloy (~17% silicon).
Apparently Mahle makes a 'Turbo piston' using 2618 alloy, but those were only available for the 6.0L at the time, not the 5.7L. W2W sells 2618 alloy Mahle pistons for $920.
Mahle dished
I'm going back to Diamond forged 2618 this time for my LS3. I was concerned that the Diamonds also have a full dish with a flat edge (catalog pics showed reverse dome), but talking to Nick D'Agostino at Diamond he reassured me that the quench area is fine at .300" ledge, though they did discover detonation problems with a narrower ledge (the Mahle have a narrow ledge). The Diamonds have a nice .260" top ring down, and I went with a 3.622" stroke to keep the oil ring from overlapping the piston pin.
Diamond dished
Mahle dished
Diamond dished
The guy who built my motor went with Wiesco. He said wiesco has the deepest skirts which helps against any boost blow-by. I honestly don't know how true that is but it sounded good at the time.
I know wiesco, mahle and diamond are all good piston choices though.
I have used all of the above and they are all equivalent assumming the same alloy. It comes down to customer service and turn around time. I am having major grief with one of the above companies giving me the right rings for their pistons. They went as far as telling me to go ahead and use a set of rings that came with their pistons that had an almost 0.040" end gap! That was on a set of file fits, so there was no reason for this to happen in the first place. Second set they sent me were 0.028 and 0.035's.
Ive run Diamond in a couple motors and could of ran Mahle in the my newest moter...... but Shawn from VA Speed and Myself started talking..... we decided to go with a custom set of JE Pistons....
If ya have to choose between the Mahle and Diamonds.....
Im sure VA Speed has them cheaper then any sponsor by about $75-100.
Kyle
Kyle
I used some Mahle's, that looked just like Blue's..
Mine worked perfectly, and I abused the life out of them I even re-fitted them for a while last year when my 382 expired. I still have them, and they are still in excellent condition....my standby pistons lol.
Mahle make some of the best pistons around, as do Wiseco etc
There are plenty of choices really.
I'm about to find out how good the Mahles are. My enigne builder ordered custom gas ported JEs for my .030 over 402 (now 408) but after 6 weeks he gave up & ordered the Mahles & they came in a week. I had Diamonds in the 402 & they held up to 2 years of racing. Because of the long stroke they did have some skirt scoring, so if you are running a stroker I'd say get any of them coated.....
Mahle dished
Diamond dished
Mahle dished
Diamond dished
