pics of my sdce 8 rib setup!!!
Restricted User
i installed this kit about 3 months ago! i love the kit and have had zero problems with it. the people at sd concepts were very helpful and answered all my questions and concerns. i even got the belt perfectly aligned the first time!
TT-TECH Veteran
Looks good! I would definately be working on a real air filter for it. It took me about 3 hrs to make my own from stuff I picked up at Pep Boys LOL! A guy Mark from Louisiana helped me with his photos he posted etc... I am using 4" aluminum pipe with a filter works good required a little trimming of the core support though.
How close dose the crank pulley run to the idler pulley, sure looks close.
I guess there is no room for a larger crank pulley, 7-5/8 would be out of the question???
But than again with no slippage, I guess you could pulley down on the blower side, to make up for it????
What crank pulley are you running?????
Since your making some decent power and have a good penny in your engine, I would quit running that $2 fram filter and run something with a synthetic element like a mobil 1 or k&n. I read a lot about those fram filters coming apart.
Restricted User
i used to only use k&n oil filters but stopped caring because i didnt think they really did that much of a better job.
Nice job!
That's an interesting SDCE/Custom setup you have there.
Different than your typical ATI D1SC.
Looking at your pictures, it appears you did some motor work too.
That's a nice ride you have there.
Restricted User
Looks good, but you are going to need to change out that screen pretty quickly to a heavier stainless mesh. That screen will flex back and forth as you rev and shift and break pretty quickly and you know where it is going to goe first...
Jim
Jim
whats the price difference between the one you have and the 8 rib procharger sells?? reason i ask is because i am going to be doing an 8 rib set up and i need the best proformance.
Restricted User
