Turbo and Injector size
Old 02-15-2008, 03:34 PM
gremjimi70's Avatar
Default Turbo and Injector size
I have a 5.3L, I want 550-650 hp what size turbo(single setup) do you guys think and can the stock 28lb injectors be enough?
Old 02-15-2008, 03:43 PM
ninetres's Avatar
No. Get 60lb injectors.
Old 02-15-2008, 09:01 PM
gremjimi70's Avatar
Default 42?
What about 42lb would that be enough?
Old 02-15-2008, 09:14 PM
Grr
Grr's Avatar
get 60# injectors, or go carbed, simple as that
Turbo, for that power 70mm would be fine
Gary
Old 02-15-2008, 10:59 PM
ninetres's Avatar
Did you miss post number 2? Go back and re-read
Old 02-16-2008, 04:29 PM
kbracing96's Avatar
My 42's in my 4.8 are maxed out at 12lbs boost and making 505rwhp
Old 02-16-2008, 04:32 PM
99SS-T's Avatar
500 is about as far as u wanna push 42's. Mine were nearly at 100% duty cycle at the 531 i made when i still had 42's. You dont wanan be near 100% as that is insuring that they will fail over time. Get 60's. Its not much more and its WELL worth it.
John
Old 02-16-2008, 07:24 PM
gremjimi70's Avatar
John, what size turbo are you running? Is there a good place to find compressor maps on the web for popular turbos? I want to build boost low and spin up to 6000-7000rpm.
JIMI
Old 02-16-2008, 10:00 PM
dredoggy's Avatar
Smile
here is a site for turbo size calculations hope this helps. http://www.smokemup.com/auto_math/turbo_size3.php
Old 02-16-2008, 10:14 PM
Sideways240sx's Avatar
60's for sure. 28's might be fine for a heads cam/wet shot to hit 550rwhp, but not in a boosted app.
If you dont get the 60's you will wish you did, and your not gonna sacrafice any driveability with them.
Good luck, Chris
Old 02-16-2008, 10:46 PM
2002ws-6's Avatar
you want some 42's I'll have a set as soon as I get my 60's dohhhhh
Quick Reply: Turbo and Injector size
