F-2 blower to big for a 408?
Old 02-16-2008, 10:55 AM
01red28's Avatar
Default F-2 blower to big for a 408?
I have a F1-A the moment but I have the opportunity to upgrade to a
F-2 if I were to go ahead and run the F-2 would I have to run a cog system or is an 8rib up to the challenge?
My goal is to break 900whp what I have is a 408 with a CR of 9.6 cometic head gaskets studded all the way around with Callies rods and crank Diamond pistons and the crank is keyed, but my heads are stock 6.0
Any info would be great thanks everyone
Old 02-16-2008, 11:00 AM
Jake@EPP's Avatar
The f1a will make the power your want, it just will have to have optimal componets and high boost.
A f2 will most likely take less power to spin at that level and make the same hp. It is a much larger unit, and will take a custom bracket. I would not even try a 8rib with this, you will get carried away and crank that boost up
A custom 12rib or cog would be the best best, we all know a f2 is not a daily driver unit.
Old 02-16-2008, 06:32 PM
xfactor_pitbulls's Avatar
F1R should be the right head unit for what he wants to do, right? Brackets are already there and you dont have to deal with the extra head unit size in a tight engine bay.
Old 02-16-2008, 06:50 PM
Jake@EPP's Avatar
A f1a will do it no problems, a f1c would be the biggest i would go with A2A. The f1r will make a bit of heat cranked up so get ready for the W2A ic.
Old 02-16-2008, 07:25 PM
platinum1's Avatar
i am running a f2 and a 250 shot on mine.o yeah my custom etp one off cylinder heads also finally came in!
Old 02-16-2008, 07:56 PM
Websy21's Avatar
F2, damn, there are quite a few on this forum that run a 408 with a D-1 and make 750rwhp with ease so I think a F1a would suffice easily for that power level you want
Old 02-16-2008, 08:00 PM
platinum1's Avatar
i am running my f2 and 250 shot on a 416
Old 02-16-2008, 08:56 PM
01red28's Avatar
So how much boost can i run with an 8 rib on the F2 before I run into problems?
Old 02-16-2008, 11:17 PM
eb02z06's Avatar
You can't spin a F2 with a 8 rib-at least not enough to make it worth running.
Old 02-17-2008, 03:08 AM
xLBx's Avatar
I had problems with my D1 on a rib belt. Cog is the only way to play
Old 02-17-2008, 06:22 AM
speedracer5532's Avatar
I made 914rwhp on a 402 with only 14.5 lbs of boost with a F1A. I did turn the boost up more but never dynoed it again before I pulled the motor. I am building a LSX 427 now and plan on staying with the F1A.
Old 02-17-2008, 08:14 AM
EPP
EPP's Avatar
We will be tuning in this 402/F1A in the next several days, it has a six speed so it should make good numbers. http://www.exoticperformanceplus.com...Car.php?car=29 Bob
Old 02-17-2008, 10:14 AM
02SSLE's Avatar
bigger is always better.
Old 02-17-2008, 12:21 PM
Jake@EPP's Avatar
Aint that the truth. I have never personally seen a f2 with a 8rib setup so i would not know. But a bigger wheel and different impeller pitch would make things alot worse for belt traction with a 8rib.
Old 02-17-2008, 05:21 PM
Closed ex-Sponsor Account
sho-me speed's Avatar
how much are the 12 rib crank pulleys for the ATI balancers? do you have any in stock?
Old 02-17-2008, 07:14 PM
Jake@EPP's Avatar
Funny you ask, we have been throwing around the idea of figuring out a 12rib setup for Bobs race car. Spring loaded is a MUST in a situation like this. There is a bit more to it then just changing crank pulleys, its a whole new system per say. Its a in-the-works status right now
Old 02-18-2008, 01:55 AM
chuntington101's Avatar
why cant you run a 8rib?? its what some of the corvette guys are doing. and there is even one guys looking to run his F2 (with cog drive) as a DD car! so what makes the F2 a race only supercharger??
Chris.
Old 02-18-2008, 04:23 PM
Kuhnstyle86's Avatar
Chris.
I hope he likes buying belts...
Quick Reply: F-2 blower to big for a 408?
