X/H pipe for FI? (Supercharger)
Old 02-19-2008, 06:21 PM
Soul Crusher's Avatar
Default X/H pipe for FI? (Supercharger)
I know on NA and nitrous cars an x or H pipe helps with the scavengeing effect but is this really nescessary on an FI car? Spescifically a supercharged car (obviously).
Old 02-20-2008, 03:02 PM
Maybe this belongs in the advanced tech forum?
Old 02-20-2008, 03:09 PM
onoiocoko's Avatar
don't count me as a tech, but i would say the supercharger definantly because there is nothing different in the exaust. even with a TT set up i would think it would help. single turbo would probably be close to useless though.
Old 02-20-2008, 06:37 PM
xXxSilveradoxXx's Avatar
Obviously!
Old 02-20-2008, 06:50 PM
MonochromeSS's Avatar
It will definitely help a supercharged car scavenge.
A twin turbo car... maybe help equalize the pressure in both turbos? Not sure what it would do if anything. But i don't really see it doing much in a TT car, especially with the way most TTs are setup piping wise.
Old 02-20-2008, 07:05 PM
FieroZ34's Avatar
Well, necessary it is not. But very few performance parts are necessary on any F/I car. Cams, intakes, heads, exhaust mods, and most all other mods of the like really aren't necessary for big power. But practically is another story, as you don't want to have to run 30psi to make 500rwhp.
A good X pipe will help, however how noticeable it will be is arguable and depends on the car. If you are building your exhaust, and can fit it, there's no reason not to. But I wouldn't redo your exhaust system or sacrifice ground clearance solely so you can add one.
Definitely not..
Quick Reply: X/H pipe for FI? (Supercharger)
