whats the most power from a p1sc??
Old 02-23-2008, 03:26 PM
Rickys S/C Z28's Avatar
Default whats the most power from a p1sc??
i have tried to find out using the search but had no luck, so what is the most power anyof you have seen through a P1? im shooting for 600 RWHP and want to see how close i will be. thanks guys!
ricky
Old 02-23-2008, 04:16 PM
b727pic's Avatar
its possible.....I'm at 667/702 on shorty headers and a poor flowing exhaust setup.
Old 02-23-2008, 04:19 PM
sciff5's Avatar
I know Vseriestech is on a P1sc and he is most likely pushing 600+
I deff think its possible... even if you only get 550.. your only a 50 shot, or a little more boost, away from your goal.
Old 02-23-2008, 04:32 PM
cool has any one went over 700 om a P1? and b727pic how does the 408 pull with the p1sc on it i was told that it was not enough blower for the 408?
Old 02-23-2008, 06:48 PM
lionelc-5's Avatar
Stock block and 575HP 505 TQ on a P1SC-1
Cam, headers and G Foce tune.
Old 02-23-2008, 06:59 PM
MonkeyBoneSS's Avatar
Didn't a member named "oakland...." put 680ish at the wheels on his SS?
Old 02-23-2008, 07:03 PM
Found the thread right here!!
https://ls1tech.com/forums/showthrea...282&highlight=
Old 02-23-2008, 11:43 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
600 RWHP is doable with a P1SC.
Old 02-24-2008, 08:57 AM
V-seriesTech's Avatar
615rwhp 565ft-lbs 7.5 psi
afr 205's,Trak cam,fast 90 GM 90,LG pro long tubes, 60's....
Old 02-24-2008, 09:48 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I did 632 on my old setup in my sig...
Old 02-24-2008, 11:15 AM
b727pic's Avatar
My car is a pussycat around town, very stealthy (by design). But when its time to "Play" its as fun as fun can be.....1st, 2nd, and 3rd gear are totally useless with the go pedal mashed (stock tires).....even in 4th gear she can get a bit squirrely.
The key to the P1 is the impeller RPM, on the GTO the crank pulley is only 7" trying to get a blower pulley small enough to rev up the blower will result in sub 3" pullies and most likely belt slip. I went with a custom 8" crank pulley from ASP....totally changed the way the P1 behaves, boost comes on much quicker due to the higher revs. My setup maxes out the P1 impeller at 6500 engine RPM....
Once my exhaust system is dialed in, the boost will go down some. I would expect by as much as 2psi....time will tell.
As for a P1 not being good for the 408???? it all depends on your goals and expectations. 600+ doable......700+ might be iffy, just too many variables...ie SCR, DCR, cam, heads, intake, exhaust etc....
Old 02-24-2008, 02:44 PM
Pray's Avatar
I did 632/550 at 6,200 with 10psi boost restriced on my cam/exhaust only 02 Z06. The restrictor was subtracting 3lbs of boost and the cam pulled to 6,700. I was getting 23rwhp per lb of boost so do the math. I think at 6,700 with 13-14lbs I would have been over 700rw. I just wasn't willing to find out with the stock short block. I was running an A&A kit with a 3.85" pulley and a 224/228 .588/.595 114 cam with Supermaxx headers.
Old 02-24-2008, 02:48 PM
FRCBobby's Avatar
nice numbers guys. Mine has done 622/504 stock heads / stock bottom end.
Old 02-24-2008, 02:50 PM
Pray's Avatar
If you get an ECS boost restrictor you can pulley down and bump up that tq and still make that same hp up top. The curve ends up looking more like a N/A curve but you get alot more usable power. Just a thought.
Old 02-24-2008, 05:48 PM
Nice. What size pulley and how much boost?
And,..are you guys useing METH? I haven't...as i'm a little affraid to depend on it.
Old 02-24-2008, 07:38 PM
EPP
EPP's Avatar
To get the most horsepower out of the P series I would go for a higher compression ratio. 11.0/1 and methanol should do the job, and you'll get some good power out of it. Bob
Old 02-25-2008, 07:18 AM
red fury's Avatar
good info....
Old 02-25-2008, 09:04 AM
FRCBobby's Avatar
I am unning a 3.85 pulley and seeing 11psi.
I am running the Alky Control meth kit, I highly recommend it with FI.
Old 02-25-2008, 08:08 PM
wow guys!!! this is the stuff i wanted to know!!! give me a lot of hope know that i HAVE to build my motor! Bob i hope we can make these kinda numbers!! but my car wil only be around 9:1 on the CR because i know that ill want to runn an F1 next year but i want to get as much power as i can out o fthe P1, and would like for it to be very safe!! i think ill be happy with anything over 600RWHP
Old 02-25-2008, 11:29 PM
rick@latemodelspeed's Avatar
Default Another Procharged ZO6 by Late Model Speed - 645RWHP/579RWTQ @6PSI details inside
We just finished up another Procharger package for a customer. His car is a beautiful '08 Z06 model in Atomic Orange with the highly desireable comp grey wheels. We were able to see a little more RWHP on his car than usual, but I attribute this to the Corsa cat back exhaust system that he had us install. We normally just use the headers, X-pipe, and factory cat back. In this case, it seems the Corsa added roughly 20 RWHP! He also opted for the high temp header coating, and a set of our brand new custom coil/engine covers from Roto-Fab!
With permission, here's a dyno graph, and a few pics for you all to enjoy
http://www.lmspeed.com/index.asp?Pag...PROD&ProdID=64 view images
Quick Reply: whats the most power from a p1sc??
