blower speed-RPM calculator formula?
Old 02-27-2008, 12:44 AM
Restricted User
Lawnboy's Avatar
Default blower speed-RPM calculator formula?
I need the formula to figer out what my blower speed will be,
does anyone know the math, i used to have it.
thank you for your help
Old 02-27-2008, 07:42 AM
ss1
ss1's Avatar
Procharger I assume?
edit: never mind, I just saw your other thread.
Old 02-27-2008, 08:02 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
engine RPM x pulley ratio x blower step up ratio
Old 02-27-2008, 08:07 AM
b727pic's Avatar
Here ya go..
Just enter your application pulley sizes / gear ratio / and engine RPM.
Old 02-27-2008, 10:06 AM
rufretic's Avatar
Originally Posted by b727pic
Here ya go..
That calculater is awesome! Makes it super easy to figure out. Thanks. I still have a lot left in my little D1, should work just fine with my new 408 set-up.
Old 02-27-2008, 10:37 AM
No Juice's Avatar
I believe the D1 kit comes with a 7.25 crank pulley and 4.5" blower pulley which is suppose to be about 8psi. Can anyone verify that?
If so I'm at 42936rpm and its making about 10psi on a stock LS1 and I've still got another 19000 to go
Old 02-27-2008, 11:02 AM
b727pic's Avatar
Happy to be of service
Old 02-27-2008, 11:05 AM
b727pic's Avatar
Not sure about the F body, but the GTO was a 7" crank pulley. I had a custom 8" pulley made by ASP to get my RPM's up on the impeller yet still keep enough belt wrap on the blower pulley to keep belt slip to a minimum.
Old 02-27-2008, 11:46 AM
ChevyChad's Avatar
SDCE uses a 7.25" crank pulley. The ATI 8 rib crank pulley is 7.65"
Restricted User
Lawnboy's Avatar
Hi b727pic
thank you for your help but i cant open the file, can u send me the link to the procharger calculator, i cant find it either on there sight
thank you very much
Old 02-27-2008, 12:21 PM
b727pic's Avatar
Originally Posted by Lawnboy
Hi b727pic
thank you very much
responded to your PM.
If you dont have Excel you can't open it.
If you do have excel not sure why it wont open??? I can always email you the calc, but you will need MS Excel or excel reader...
Old 02-27-2008, 03:38 PM
ChevyChad's Avatar
maybe he doesnt have winzip?
Old 02-27-2008, 04:22 PM
b727pic's Avatar
Could be...
If anyone needs this, simply shoot me a PM, I can email it to you.....
Old 02-27-2008, 04:34 PM
ChevyChad's Avatar
although it really is not hard to do the math yourself
Old 02-27-2008, 04:52 PM
No Juice's Avatar
Wow, guess I was a little off
Old 04-03-2008, 08:32 PM
firehawk618's Avatar
Here ya go..
Thanks for the spreadsheet. Makes it real easy!
Quick Reply: blower speed-RPM calculator formula?
