Preliminary Dyno #'s from my new F1A/402/AFR225 combo
Old 03-05-2008, 03:51 PM
eb02z06's Avatar
Default Preliminary Dyno #'s from my new F1A/402/AFR225 combo
Well I finally got my belt issues sorted out and had a chance to see what this little "F1A" can do. It's about the same size as D1SC or P1SC-the gear case is where the thickness comes-it's interchangeable with any of those blowers in case you wanted to upgrade. It's just an "off the shelf" 402 built by "SLED28" here and the heads are "out of the box "AFR225's 72cc, Cam is my own grind that I'm testing, LS6 intake, Stock TB, Stock GM MAF, American 1 7/8 racing headers, Magnaflow catback-great for keeping the car tame-a very nice deep rumble without being annoying.
Around 5000-5500 the dyno was switching from RPM to Speed and the graph goes skewy so the 890(861 corrected) was between that RPM. We smelled alot of rubber so were not sure if were spinng the tires or what-hard to tell when your in the car.We've already talked to Dynojet to resolve the issue so we can find out where the car revs out to. I' don't have my laptop here so I'm unsure of how much boost the blower made at 5000 but at 6900 it was close to 18lbs. This was through Rodneys Level 5 4L65E that I've been thrashing on sice last year and it's holding like a Champ!
Once the dyno's sorted out I have anohter cam to try as well as an F1R and a Victor JR. I'm sure this little F1A can hit 950 RWHP. I'm sure Frank's 427 with the F1R will be well over 1000rwhp.
Old 03-05-2008, 03:54 PM
No Juice's Avatar
So how did you fix the belt problems? And what bracket are you using now?
Old 03-05-2008, 05:38 PM
MY99TAWS6's Avatar
Wow big power! I thought you had to go speed density past 600 rwhp or so? You are still running the stock maf? I am hoping to hit 850rwhp at 15 to maybe 18psi on my combo.But its an m6 so should be a bit easier than your auto. Dave is buidling me a new 408!
Old 03-05-2008, 06:02 PM
eb02z06's Avatar
Your in good hands with Dave-who says you have to go SD after 600rwhp? You'll hit your numbers easy!
Old 03-05-2008, 06:51 PM
venom ws7's Avatar
Great power through an A4 man Congrats and great work.
Old 03-05-2008, 07:15 PM
TT-TECH Veteran
Inspector12's Avatar
Good results!
Old 03-05-2008, 07:24 PM
helicoil's Avatar
Default F1a
Is that little dip at the top signs of valve float?
Old 03-05-2008, 07:38 PM
eb02z06's Avatar
No bro-what's happening is after around 124mph or say 5400 the signal gets lost and Dynojet is trying to make it up using drum speed. So the 890 is really at 5500 or so. Were not getting a good signal so we talked to Dynojet and we know what to do now-we need to get the signal from the coil. Were going to do that on saturday and post up the results!
Old 03-05-2008, 09:03 PM
crashinaz's Avatar
NICE! FYI - We ran into the same problem with my car on a Dynojet... Just grabbed the wire off the coil and switched to low voltage induction... Problem solved.
Old 03-07-2008, 06:39 PM
SLED28's Avatar
We ended up making our own bracket and its working good so far. We will try a F1R on the car soon and see how it holds up. We are hoping to have a bracket that will make 1000+ rwhp without issues. Then we can go into full production.
Old 03-07-2008, 08:31 PM
helicoil's Avatar
O.K., I am curious what kind of seat pressure you are running on that beast. I have all very similar hardware for mine. Whose intercooler and what kind of IAT's are you seeing. thanks
Old 03-07-2008, 09:21 PM
LS1Tech Sponsor
Slowhawk's Avatar
You definitely lost something up top.Looks like boost to me by either belt slip or floating valves.
As for the tach signal.Clean all the grounds in your car and add some more.Vette's are known to have a bad grounding system which screws up the tach lead.
Old 03-07-2008, 11:26 PM
eb02z06's Avatar
Hey bro-it didn't lose boost-it made 17.78 psi-it did switch from rpm to speed-going to tap into the coil tomorrow then we'll see-the cam may have too much advance-I have anohter grind rieady to go in if thats the case!
Old 03-08-2008, 09:09 AM
SLED28's Avatar
My turn on the cam selection this time, you've had your chance. No more Ford cams in my motors. We do have quite a bit of spring pressure, I doubt its that.
Old 03-08-2008, 09:12 AM
platinum1's Avatar
FORD-BAH HUMBUG!
Old 03-08-2008, 09:25 AM
Websy21's Avatar
Wow, still on the maf............. I always thought too that SD was highly reccommended when making serious horsepower as well? Or is it that you just make more? BTW congrats on some sicko numbers!
Old 03-08-2008, 09:29 AM
moehorsepower's Avatar
People always talk about maxing the maf out and it cant be done, My LT1 with a STOCK maf only descreened made 722 RWHP on Fast Gas at 14lbs of huff...
Old 03-08-2008, 09:50 AM
Websy21's Avatar
Ya, I don't know much about tuning but I thought it was b/c at a certain point it was almsot at the point where the MAF was blind. Also the fact that you can make more power on a SD tune while having better peramaters to 'fine tune' it.
Old 03-08-2008, 10:19 AM
eb02z06's Avatar
The MAF is maxed out at 3500 rpm-so it's blind for along time. SD is the more accurate way to go but it doesn't offer more power.
Old 03-08-2008, 01:48 PM
Frost's Avatar
Your MAF tune will become a totally weather-dependent tune if it's maxxed by 3.5K. From a cold to hot day you will have a large AFR variation.
Sick numbers, I just wouldn't want a setup that I had to tweak on every single time the temperature changes 15-20degrees. Just my 2cents.
Quick Reply: Preliminary Dyno #'s from my new F1A/402/AFR225 combo
