Where, and how did you put your iat sensor in?
Old 03-11-2008, 04:54 PM
Sideways240sx's Avatar
Default Where, and how did you put your iat sensor in?
People with custom turbo kits, where and what did you do with the iat sensor? did you drill a small hole in the pipe, get a new gromet, and shove it in, and hope it doesn't blow out?
I have been suggested by some to do it this way, but id like to know what you guys have done.
Thanks, Chris
As always a picture would be great.
Old 03-11-2008, 05:24 PM
Reject's Avatar
i read a while back that you had to get a IAT sensor off of like a boosted car already that is "threaded" so that it dosnt get pushed out.
i dont know if i read that right but that's what i heard
Old 03-11-2008, 05:35 PM
That would be an option if there was a sensor that was plug and play... Which i dont know, so hopefully someone chimes in hear, and gives us some help, since its something both of us will have to do very soon....
Chris
Old 03-11-2008, 05:44 PM
Reject's Avatar
if i had to guess, i would think that it would be best to have it as close to the TB as possible to give the computer the truest reading just as it's entering the engine. my only concern would be when you spray some alky, if it would damage the sensor or not.
Old 03-11-2008, 06:03 PM
I was gonna put it right by the maf, and tb unless im told otherwise.
Old 03-11-2008, 06:06 PM
Reject's Avatar
oh woops forgot you were going to go with the MAF, i didnt really pay attention to MAF'd car's and their IAT sensor location, i think though it would make good sense to have it near those meter's to give you the truest reading
Old 03-11-2008, 06:26 PM
Yea gonna try the maf for a little while. My tuner prefers to keep the car maf if they can for driveability, Once i get the power up a little next yr, it will probably go speed density.
Chris
Old 03-11-2008, 07:43 PM
Turbo Addict
RICE ETR's Avatar
I just drilled a 5/8" hole and reused the stock grommet and IAC as it was used in the Ls1 lid...hasn't blown out yet.
Turbo Addict
RICE ETR's Avatar
edit...I think the hole is 5/8"...just measure the factory hole in the lid
Old 03-11-2008, 08:07 PM
frcefed98's Avatar
GM # 25036751 is the PN I have on file for the thread IAT sensor.
I just did the new grommet and drill a hole technique, tons of miles and has never popped out once.
J
Old 03-11-2008, 08:16 PM
Reject's Avatar
have any pictures of the location? i tried looking at your Fquick but the pictures are to small to make it out
Old 03-11-2008, 08:52 PM
Cool. thank you guys very much. Im gonna pick up a new one. Thanks, Chris
Old 03-11-2008, 09:05 PM
AmericanMuscle33's Avatar
I ran my stock IAT through a die, so it is now threaded. I have a vortech elbow that I tapped to match (or it came tapped....its been a couple years) either way, its threaded, well sealed, and I never have to worry about it.
Old 03-11-2008, 09:07 PM
I've sprayed 3-4 gallons of roughly 50% alky past my sensor, and it hasn't seemed to affect its performance what-so-over. Maybe someone who's sprayed 10x that amount will chime in....or anyone who's ever killed one.
Old 03-11-2008, 09:19 PM
DMH Fabrication's Avatar
Just get a threaded sensor from advance auto or napa or anywhere like that. Search on here and you will find the part number and vehicle it comes on stock. Its cheap. I always tig a bung and use the thread sensor on any of my cars or customer's cars.
Old 03-11-2008, 09:23 PM
Reject's Avatar
is it like an 02 bung that you use?
Old 03-11-2008, 09:28 PM
http://www.napaonline.com/MasterPage...erature+Sensor
I just looked up a 1991 GMC Syclone to find it. It should plug in the factory plug fine...mine all have. Also plugs into the BS3 harness.
It says 3/8 - 18 thread on there. I have always used NPT bungs and they worked fine.
Old 03-11-2008, 09:29 PM
frcefed98's Avatar
Its hidden out of the way, under the charge pipe before the TB. I'd have to take the charge pipe off to get a good pic of it.
I'll try to get a good pic of it tomorrow when I have some daylight.
69vette, I posted the GM PN. If you need to take that # to NAPA, Checker, Pep boys and have em cross reference it and they'll fix you or whoever is looking for one up.
J
Old 03-11-2008, 09:32 PM
frcefed98's Avatar
You are correct sir, here is the data page for the sensor:
http://www.pe-ltd.com/Downloads/air_temp.pdf
Old 03-11-2008, 10:53 PM
Best place to get the 3/8 18 fitting? i found 1 @ summit says its 3/8 but doesn't say its 18 threads per inch...
I was looking for a weld in nut, but there all 3/8 16. I also need a mild steel one to be able to weld it to my pipeing.
Thanks, Chris
Quick Reply: Where, and how did you put your iat sensor in?
