Made some progress on the turbo build...
Old 03-14-2008, 03:28 PM
Fireball's Avatar
Smile Made some progress on the turbo build...
pressure side of the fuel system is plumbed...still need to mount the fuel cell and run the feed/return lines...Aeromotive rates this setup to support 3500 hp
-12 to pump, -10 from pump split into 2 -8 lines to rails. Other side of rails -8 to regulator and -10 return
Mounted the vacuum pump puke tank...-12 line connecting pump to tank
Figured out the "super short belt" mod.... crank and alternator only
Oh...and its now a true drag radial car...315/60/15s...
Old 03-14-2008, 03:37 PM
Z06PSI's Avatar
Very nice.
Old 03-14-2008, 04:00 PM
W8N2SQZ's Avatar
The Car looks good!!
Old 03-14-2008, 04:20 PM
Reject's Avatar
hmmm fuel system looks like you took it from a kia just kidding
man thats a very impressive build you have
Old 03-14-2008, 04:35 PM
sr71bbjr's Avatar
looks good man...
Old 03-14-2008, 05:08 PM
deadmanTA's Avatar
Love that radiator setup! What kind of pump(s) are you using to feed those monster fuel lines?
Old 03-14-2008, 05:20 PM
LS1TECH Sponsor
DrTurbo's Avatar
You should have a nice big monster bolted onto that very soon
Old 03-14-2008, 05:45 PM
frcefed98's Avatar
Wheres the turbo????
Those guys whittling the aluminum away with a hand file over there at the turbo factory?
Build looks first class Are you doing all the turbo set up fabrication yourself? Gotta love the sideshot pic of the meat too.
Old 03-14-2008, 05:49 PM
Fireball's Avatar
aeromotive belt drive pump
Old 03-14-2008, 05:51 PM
Fireball's Avatar
Sometimes I wonder
Tyson at Performance Auto Fabrication did all the pipe work...Stuff I welded looks like crap
Old 03-14-2008, 05:54 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
car looks damn good!
Old 03-14-2008, 06:08 PM
frcefed98's Avatar
Can't wait to see some shake down passes.
Old 03-15-2008, 10:13 AM
SSilverSSurfer's Avatar
what kind of fuel tank you running?
Old 03-15-2008, 10:21 AM
7 Second Club
Phil99vette's Avatar
Brian,
Car looks great, how long til its done?
Old 03-15-2008, 11:09 AM
Websy21's Avatar
Thats a very nice, crazy build you have there. Keep up the nice clean work!
Old 03-15-2008, 12:30 PM
Fireball's Avatar
3 gal cell in rear
Old 03-15-2008, 12:31 PM
Fireball's Avatar
Originally Posted by Phil99vette
Brian,
few months I hope
Old 03-15-2008, 03:14 PM
what kind of gasket did you use between the tb and the intake?
Old 03-15-2008, 03:46 PM
Fireball's Avatar
I made a gasket out of rubber sheet. Had to make an adapter to use the FAST style TB with the Ford style elbow.
Old 03-15-2008, 04:11 PM
can i make one for my sheetmetal elbow/stock TB out of the same material as a carb gasket? sorry to hog your thread
