38mm WG...need help on BOV
Hey have a 38mm tial WG searched that that would be fine for me (or at least i interperated it as it would be...) anyways have a TC76 on a 346ci with 317 heads on a stock cam. was reading that i would need a 50mm BOV....going to try and explain it the way im reading it, for low boost numbers you need to order a larger one to allow it to bleed off more air quickly, and when running bigger boost you need a smaller one, am i right on that?
have a .6 baro spring on the WG but dont know what spring size to get on the BOV, i know you do it off based on intake vacuum....but i dont know what that is on a stock car.
help me out, i'm pretty sure i'm screwing up alot of information
More boost - less gate
Less boost - more gate
If you are looking at the Tial 50 - I would go with the 7psi spring, you can order it with the gate or afterwards...I usually go heavier (11psi) and it works fine, also it is easier to hear it surge once then leak for months...
LS1 F body turbo kit. This is a stage 2 turbo kit with inter cooler tial 44mm b o v
waste gate injectors headers up pipe down pipe 62mm turbo makes 502whp at 9.5 psi of boost e boost 2 boost controller and mutch more i only recommend this for a standard transmition we have went thru 4 4L60e transmitions and a couple of turbo 400s the motor finally gave out at 130,000 so i decided to sell this turbo kit and put a used motor in the car and sell it, this turbo kit was purchased for 6,000 has about 15,000 mi on it,this comes with a water methonal kit also. contact @ bawb4787@hotmail.com or 479-806-3007
so....
is this a sale pitch?
