Boost Cam
Kettle of worms.. going to hear arguments if you search a bit for no split, reverse split and normal split and for higher lift, lower lift and high and low lsas. Seems turbos will work pretty good with almost any cam actually. Depends a bit on backpressure and all that stuff too maybe.
Thats said I am using what lingenfelter calls their turbo cam. They used to use their gt2-3 on most of their builds and now like the gt7 maybe gt 11 on the wilder stuff. These are very similar to some years of z06 cams incidentally.
ling and z06 cam specs.
01 ZO6 cam: 204/211 .525/.525 -116 LSA
Lingenfelter GT2 205/212 .540/.540 –116.5CL
02-03 ZO6 cam: 204/218 .551/.547 -117.5 LSA
Lingenfelter GT2-3 207/220 .571/.578 –118.5CL
05-07 ZO6 cam 210/230 .561/.557 –120.5 LSA
Lingenfelter GT7 208/230 .554/.546 –121CL
Pretty simular don't you think?
I would like to see some more dynos of bunch of different cams on same turbo engine maybe high tech performance could do a test with the new two piece timing cover on engine dyno.
You are fine. As stated above, some people say go large or small or mild. With a 118lsa and some say 110 lsa. Just keep the cam you have, I do not think the gain will be worth the swap.
