Main girdle?
Old 03-20-2008, 02:07 AM
valiant65's Avatar
Default Main girdle?
I have searched but not found answer. Are you guys using your main girdles with stock caps or billet caps? I mean, if I'm trying to get about 700 rwhp out of stock crank alu 347, do I need both, billet caps and girdle, or does the girdle strengthen those stock caps enough?
How about iron truck blocks, do those need billet caps and/or girdle also at that power level?
Old 03-20-2008, 08:02 AM
Z06PSI's Avatar
LS6 block with girdle and mains pinned here or at least it is being built.
Old 03-20-2008, 08:05 AM
Mr.MartyStone's Avatar
I would pin the mains before I would even think about a girdle. The girdle only ties the main caps together, not the main caps to the block which is what pinning will do. The katech billet mains are very inexpensive and already have dowels built in...Steve at RED can install them on the cheap too.
Marty
Old 03-21-2008, 06:44 AM
valiant65's Avatar
So, to minimize machining costs, an iron block would be easier? Or do those iron ones still need the same operations, caps and girdle? Anyone?
Old 03-21-2008, 08:22 AM
Z06PSI's Avatar
Well pinning is really minimal but the girdle is expensive. I plan putting some significant boost on mine though.
Old 03-21-2008, 08:23 AM
jason02Z's Avatar
run a girdle if ur when u do an aluminum block even for 600hp it will keep the motor from twisting under load..and do the mains. the girdle pretty much bolts in and cost 400.00 not that much when its holding ur $4000+ motor. if i stay aluminum i'll be running a girdle
Old 03-21-2008, 08:39 AM
DuronClocker's Avatar
Speed Inc. talked me out of pinning my stock caps and to just run ARP main studs. I'm aiming for somewhere around 650-700rwhp with my D1SC.
Old 03-21-2008, 09:31 AM
TwnTrboCE's Avatar
Well I can tell you by real world experience what works.
Stock crank with stock pinned caps and using ARP studs. I've been 8.50s @ 3,700lbs.
The girdle is a waste of money. The caps will still walk with alum or steel block. Have them pinned.
Old 03-21-2008, 01:24 PM
NA$TY-TA's Avatar
Thank you Mike......
Old 03-21-2008, 03:38 PM
valiant65's Avatar
Thanks, this is just what I was after! Still seems a bit funny when every book or magazine tells you that oem powdered metal caps will break after 550 hp..?
Old 03-21-2008, 04:20 PM
y2khawk's Avatar
don't believe what you read in books
racecar was 8.20's 170'ish with just studs, i run that same block and crank still in my DD truck 12 to 15 psi and 40K miles later it needs rings. That's about it
i wouldn't even blink at making 600RW on the stock parts as is, save maybe the pistons.
Old 03-21-2008, 06:27 PM
KissMySSo1's Avatar
making 1100+rwhp here with about 5k miles on the motor. only stock caps with studs.
Old 03-21-2008, 07:26 PM
black01_WS6's Avatar
what exactly is having the mains pinned?
Old 03-21-2008, 10:01 PM
NemesisC5's Avatar
Old 03-22-2008, 01:10 AM
Installing dowels into the main caps to positively locate them into the block.
Old 03-22-2008, 03:30 AM
valiant65's Avatar
Thanks guys, in my lowbudget build it is really important to buy ONLY what is necessary
Old 03-22-2008, 02:39 PM
Run stock caps with ARP main studs...problem solved.
Marty
Old 03-31-2008, 10:04 PM
stage274's Avatar
Dont be cheap, Run the Girdle, it a bad *** piece, and its a bolt in.
its a 1/4 inch of ss on top of the mains ,and it distributes the load evenly. it will Kepp everything together and stabilize your bottom end. you can get it from epp, tell bob to give it to you for a super deal , tell him to knock off 40$ off list price,bob a dealer for The girdle, bro it works well and it stops the main caps from see sawing back and forth, plus no pinning give you horsepower, the girdle acts as a oil scraper, and blocks your wind age when used with stock windage tray, you will see a 20 horsepower gain.
You will love it.
Old 04-01-2008, 02:59 AM
flash12t's Avatar
You will love it.
has this been proven on a dyno ???
Old 04-01-2008, 03:10 PM
TT-TECH Veteran
Inspector12's Avatar
I can tell you I have one in each of my cars and the mains still walk! Does it help? Can't prove it either way plenty have done great with out and a few have done ok with. If I hd it to do over again it would be pinned caps with ARP studs I know that stops the caps from walking. Good luck with what every you decide I have made over 800rwhp on a 346 with just ARP studs so your goal is a easily achievable one
Quick Reply: Main girdle?
