Gone turbo single fan ?
Ok i bought a ptk style off brand turbo kit. Well I get it all together and there is no way my drivers side fan will clear. I had to pull the fans off to get the turbo on it. Whatelse can I do for my fan setup? Can I go to one big single fan and not have to worry about overheating? this is on a 98 z28 thanks guys
Spal single xtreme fan puller 3,000 cfm 16.3" tall, 3.65" thick and 15.75" wide. This will free up plenty of room and be plenty to cool a turbo motor.
Good luck,
-Tim
Good luck,
-Tim
Part # 01460 from non-sponser. I don't have any running results at this time and it is aparently a non sealed motor fan but I have run a similar style fan on a '69 Chevelle w/177 Weiand sc I had without problems on the street. It does get very dusty were I live in NM.
I will be using Evans coolant which I have in the past on stock radiator and
past D1-SC tuner kit which had a single fan on a 10#'s boost 346cu. forged set-up. That was my every day driver 23 miles one way mixed traffic.
A 60 amp fuse start and 30 amp continually will be needed for the Spal fan.
Location: sneaking in your back door as you leave!/cartersville ga
i like the idea of 2 seperate fans. that way when one dies you have a back-up. its not to often both will die out at the same time. when we used to rockcrawl i had a single fan burn-up and thats the last time i ever relied on a single fan
I doubt one puller is gonna be enough once it's summertime. Maybe with some sort of shroud?
I ended up saying fu*k it and ditched the AC on mine, stuck two big pushers on the rad. If you have to worry about how hot your gauge is getting, you'll never turn on the AC anyway.
