Oil on Pistons (pics)
Old 03-25-2008, 11:01 AM
xxxhp's Avatar
Default Oil on Pistons (pics)
Pulled my heads to do a swap to TFS 235cc and found oil on most pistons. Also all pistons where loose in their bores. The heads were completely dry. The only cause I can think of is too big piston ring gap. The engine was running fine but it would blow white smoke every once in a while.
What are your suggestions on the cause & what corrective actions should be made (other than new piston rings)?
Old 03-25-2008, 11:27 AM
Tiago's Avatar
maybe turbos are leaking oil into the compressor???
Old 03-25-2008, 11:28 AM
Dumb Ass Vette Moderator
ls1290's Avatar
White smoke is usually a sign of coolant burning. If you are not loosing oil, then I would guess it is not oil, but coolant. When you say the pistons are loose, how loose are you talking?
Keith
Old 03-25-2008, 11:42 AM
TT-TECH Veteran
Inspector12's Avatar
Yeah I would be looking for oil getting into your intake track like Tiago is suggesting. The white smoke can be either coolant or oil depending on where it is entering the motor it can also be blue or black which is more comon. And runnning a car real rich can cause build up on the pistons also usually not so wet looking though.
Old 03-25-2008, 11:44 AM
stevieturbo's Avatar
Where's the oil ? Doesnt particularly look anything too bad in those pics ?
Old 03-25-2008, 11:51 AM
TT-TECH Veteran
Actually you are right stevei I looked again and really don't see anything that bad I saw the one picture that looked wet, but forgot about pulling the heads and coolant etc... Looks like a little bit of carbon buikd up and not much more.
Old 03-25-2008, 12:05 PM
xxxhp's Avatar
Nope. The turbos, intercooler, intake manifold, cylinder heads are all dry
Keith
Iam sure it is not coolant as I haven't burned any. On the other hand my engine has always been using oil, initially it was 1 quart for 1k miles then prior to pulling the heads it was 1 quart for only 200 miles.
The pistons are rocking up, down, left & right in their bores. kinda like the piston slap thing. Looks like pistons/rings to wall clearance is too high.
If you look closely, the pistons has 2 layers of black coating on it ( you can even notice two colors). The lower coating is the regular carbon build up, while the top one looks like oil mixed with carbon.
Old 03-25-2008, 02:03 PM
Mike 01WS6's Avatar
What happened to me was what Tiago said. Turbo leaked and put oil in the chamber...white smoke. However my intercooler was full of oil.
I'd re-check your ring gap.
Quick Reply: Oil on Pistons (pics)
