few pix of the short block
Old 03-25-2008, 06:23 PM
01ramair500hp's Avatar
Default few pix of the short block
this engine is a 6.0 bored and stroked to a 408. Diamond boost pistons, howards steel connecting rods, callies crankshaft.
The engine will have a T101 or 106 hanging off the front. should make for a nasty setup. stay tuned
Old 03-25-2008, 06:34 PM
sworaz's Avatar
Looks great. What did the block, rods and pistons run you?
Old 03-25-2008, 08:18 PM
firehawk618's Avatar
Pretty much the same setup I just installed. Engine wise that is. Enjoy!
Old 03-25-2008, 08:46 PM
Turbo LS1 SS's Avatar
looks familiar
http://i3.photobucket.com/albums/y78...oBuild1134.jpg
have fun!
Old 03-25-2008, 08:56 PM
BigBenz's Avatar
cant wait to build mine. You had to bore the lq9 to make it a 408? i thought all you needed was the 4.00 crank.. Also what did all the machine work cost? New block?
Old 03-25-2008, 08:58 PM
4.00 x 4.00 = 402
4.00 x 4.03 = 408
Old 03-25-2008, 09:29 PM
BigBenz's Avatar
ahh so yolu have to have it 30 over.
Old 03-26-2008, 02:26 AM
yep .30 over. the machine work was done by proline racing in atl. to bore balance and assemble the shortblock was $1726. that also included the bearings.
Old 03-26-2008, 09:42 PM
BigBenz's Avatar
what would have been the price if you built it your self... Just had them balance,bore ect.?
Old 03-26-2008, 10:45 PM
i counted ~4200 in mine, including acl bearings, main studs, pump and chain. however, that is with the rods, crank, and pistons at cost
Old 03-27-2008, 07:40 AM
callies crank 1000, howards steel rods 1100, diamond custom pistons 800, rings 200, arp main studs 200, balance bore assemble and bearings 1726, block 750.
Quick Reply: few pix of the short block
