Anyone use washer fluid in their A2W setups?
Old 03-25-2008, 08:28 PM
nvr enough's Avatar
Default Anyone use washer fluid in their A2W setups?
I run pure water in it now but I want to get it out of storage to start tuning and it might still get down below freezing for the next few weeks. iirc MM runs an antifreeze mix, I just wondered if the cheaper washer fluid would do the same, plus I don't want the residue from the coolant if I need to drain it. Any reason not to do this?
Old 03-25-2008, 09:50 PM
MECHAM's Avatar
i run some coolant in mine too...same setup as MM
Quick Reply: Anyone use washer fluid in their A2W setups?
