Choosing turbos for twin set up?
Old 03-27-2008, 11:38 AM
youwilllose's Avatar
Default Choosing turbos for twin set up?
Is there a different kind of consumption chart for choosing twins? I am just getting in to the whole FI thing and am trying to figure out what turbos I would need for my 370. I understand how you use it to pick a single but not twins.
I have done some searching just havent found much on 370's.
Thank you for any help.
Old 03-27-2008, 05:59 PM
Anyone?
Old 03-27-2008, 06:13 PM
peter@aps's Avatar
Work out your power goals.............from there you can chose a turbo based on mass air flow at a given pressure ratio. General rule of is that 1 lb per minute mass air flow will support up to 10 HP on an efficient engine. EG, if a turbo has say 60 lbs per minute mass air flow at 10 PSI then that's sufficient mass air flow for around 600 Horse Power.
Hope that helps,
Peter
Old 03-27-2008, 11:02 PM
Well Ive got a 408 on the bottle that makes 849 rwhp on the bottle and I want to be able to walk away from it with my new project. In other words 900+ at the tire. I was thinking a couple of t61's but not to sure yet.
Old 03-27-2008, 11:25 PM
hawk584's Avatar
two mice in a wheel, when the exhaust hit's them they run like the wind!!!
Old 03-28-2008, 11:07 PM
anybody with a twin 370?
Old 03-29-2008, 02:54 AM
cracker's Avatar
Depending on your drivetrain setup, T4 61mm BB sound about right.
Precision 6176 with a .58+ exhaust housing would be a good starting point. Incredible spool while keeping the power up top.
-W
Old 03-29-2008, 11:32 AM
That is what I was thinking but wasnt sure.
Thanks
Old 03-29-2008, 12:56 PM
Mr.MartyStone's Avatar
-W
I would run .68 at least.
Old 03-29-2008, 04:55 PM
Shawn @ VA Speed's Avatar
I have to agree the 61's are about perfect for that set up,and keep with the larger a/r.If your thinking about some precision turbo's,let me know,i having a special on them this month.
Old 03-29-2008, 06:44 PM
Shawn
Do you think you could PM me a price on two of the turbos that you would recomend. The car is a 6 speed 3300# and I will be spinning it to 7-7500.
Thanks
Old 03-29-2008, 07:08 PM
Shawn
Thanks
Yes sir,i'll get you those prices when i get back in the shop on mon.
Old 03-29-2008, 09:35 PM
lcvette's Avatar
PM me too Please! thanks!
Chris
Old 03-30-2008, 05:04 AM
crashly's Avatar
i had twin 61 mm ( gtk 550) , with stg 5 turbine wheels and .82 a/r single entry..
they stopped flowing air at around 6400 rpm @ 30 + psi boost on a 355 cube engine
went .25 seconds quickeroff the trailer , from the older twin 57 mm turbonetics on the same engine, same cam, same car, came converter.
ash
Quick Reply: Choosing turbos for twin set up?
