ISO affordable merge for headers
Old 03-28-2008, 12:46 PM
MIGHTYMOUSE's Avatar
Default ISO affordable merge for headers
need 4 x 1 5/8" to single 2.5" for some turbo headers
something like this
but something like $25 each is my budget, and i would prefer a shorter one.. just the 'cone' area is all i need.
thanks, this is for my truck.
Old 03-28-2008, 12:49 PM
found this in search.. good way to spend an afternoon i'd rather shell $50 for the pair above
http://home.comcast.net/~engloid/col...collector.html
Old 03-28-2008, 01:05 PM
i finally got on the hot trail
$36 for the pair
Old 03-28-2008, 01:24 PM
LS1curious's Avatar
You just wanted press form collectors.? Those are easy to find. Post up links to where you got those $36 a pair is a good price.
Old 03-28-2008, 01:48 PM
7 Second Club
Phil99vette's Avatar
Search my recent posts, Megs has some very very nice ones.
http://www.coneeng.com/collectors.html
http://www.coneeng.com/exhaust_system_kits.html
About $100 for very high quality merge.
Old 03-28-2008, 01:49 PM
sheeeit not trying to get another thread locked for bringing cool affordable parts to the public
Old 03-28-2008, 02:47 PM
ss1
ss1's Avatar
Right click on the picture above, and left click properties. You might just find out where he found them.
Old 03-28-2008, 03:39 PM
frcefed98's Avatar
nah I won't lock it due to our sponsors not listing them for sale on their webpages. If it's something that a sponsor carries and would compete with them directly...then i'd lock it. The fuel rails are something that most of our sponsors carry so its a conflict of interest....although I didn't lock that thread
Summit racing huh? I still use them a lot, jegs too.
J
Old 03-28-2008, 07:05 PM
DMH Fabrication's Avatar
Make your own merge collectors and its costs maybe $10-15 in strait tubing or a little more if you use 15 degree bends.
Old 03-28-2008, 07:25 PM
Frost's Avatar
of course there is something to be said about the value of your time as well though. I'm sure with enough patience and the ability to scrap a few that I could make them, but then there's that material cost and my time, like I mentioned.
If I were "good" that'd be a different story though.
Old 03-28-2008, 08:06 PM
Reject's Avatar
oh god your not going to turbo the truck too are you?!?!!?
your EVIL!!!
and i'm all for it!
Old 03-28-2008, 08:13 PM
It took me about 30 minutes to cut 4 tubes and about 10 minutes to tig them the first time I ever fabbed a collector If you think about what your doing then you shouldn't have waste materials. Its not hard to cut a collector when you think about it.
Sure your time is worth something if you could have been making money during that time. I guess it comes out to about $50-75 if you took off work 1.5 hours early to make two collectors.
I think theres something to be said about the advantage of having a good collector and using the right length/diameter primarys to take advantages of the exhaust back pulses. Alot of people with turbos have the opinion that you can just turn up the boost and make up for poorly designed headers though I guess it works to a point. Should be fine for the hp MM is looking to make.
Old 03-28-2008, 09:59 PM
cast iron's Avatar
Can you expand on the right diameters and length part (forced induction?)
Thanks
if factory cast manifolds can make 1500horse then a shitty home made set of actual headers should do my truck fine
the truck had a turbo, just getting a bigger one attached to this now
Old 03-28-2008, 10:07 PM
Tiago's Avatar
nice project, going to stay AWD?
Old 03-28-2008, 11:05 PM
Thanks
Send me a pm if you have a specific set up and I can help you out on that and explain it. I believe I may even still have a back to back comparison we did on a "tuned" turbo header vs. one just thrown together to work. No need to get MM's thread way off topic though.
Yes they can work as I said above. I take a different approach on any of my cars or customer's cars. I would rather run less boost and make the same power, rather then turn the boost up to compensate for a poorly designed system.
Good luck with the project
Old 03-29-2008, 12:57 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That person makes that look and sound so easy. They can weld like a **** so it's probably simple for them, but for those of us that suck at welding....
Old 03-29-2008, 07:50 AM
yea its staying awd for sure, part of what makes this a pita!
Quick Reply: ISO affordable merge for headers
