Angle adapters for turbo intake?
Old 03-30-2008, 07:42 AM
wannabess's Avatar
Default Angle adapters for turbo intake?
My turbo sits about 2" tops from my frame rail, right now it just has a screen on it, but I want to put a filter. Where can I buy a low profile 90* bend to I can run the filter to source of cooler air?
Old 03-30-2008, 08:37 AM
Mr.MartyStone's Avatar
Cut the framerail.
Old 03-30-2008, 09:13 AM
wannabess's Avatar
Originally Posted by Mr.MartyStone
Cut the framerail.
I'll stick w/ a screen before I do that. I was thinking of using panty hose along with the screen to catch smaller particles. That's if I cant find a way to get a filter on there.
Old 03-30-2008, 09:15 AM
ls2 bait's Avatar
you could prob try the intake duct of the ls1 procharger kit but i dont know if they sell that seperately. either way at 2" u will likely be cutting or sticking with the screen. if u have a good welder to weld for u then u can just notch the frame and have them box it back in.
Old 03-30-2008, 09:58 AM
Derek @ EDO's Avatar
post pics!
I may be able to help you out!
Derek
Old 03-30-2008, 02:06 PM
wannabess's Avatar
Originally Posted by Derek @ EDO
post pics!
Derek
Ask and you shall receive...
Old 03-30-2008, 02:40 PM
Ill post a pic of what i have in a sec. Tell me if it will work, I think with some persuasion it might!
Without measurements its hard to say!
Ill take measurements of the 90 i have.
Old 03-30-2008, 03:00 PM
Its a silicone 90 so it has a flexible state to it.
Like i said, without looking at this in person its hard to tell.
I believe this is the "tightest" 4" 90 made.
The ID of the fitting is: 4"
Old 03-30-2008, 04:00 PM
wannabess's Avatar
It'll be a hell of a squeeze, I'll take measurements. I'm just worried that if I crush it too much, it's going to restrict airflow.
Old 03-30-2008, 04:23 PM
Yea, it would be tight!
I understand where you are coming from on the airflow.
Old 03-30-2008, 06:12 PM
DeltaT's Avatar
Even if you squeeze that bend in there, do you have enough room for a decent sized filter?
Jim
Old 03-30-2008, 06:18 PM
wannabess's Avatar
Jim
Well my point was if I can get an adapter in there, I'm going to route the piping to the hole in the front driver's side where most CAI usually go.
Quick Reply: Angle adapters for turbo intake?
