Drag Radial Car
Drag Radial Car
Looking At Building A 98-02 F-body Camaro For Drag Radial I Am Thinking Of Going With A Turbo Motor Lsx Base 400 Ci With A Single 106 Turbo Wondering Also If I Schould Go Blow Thru Or Fuel Injected ,it Will Have A 400 Trans , Want The Car To Be Capable Of Running Deep In The 7 's Any Idea On Cost Of Complete Engine And Even The Shop. Thanks In Advance.
W2W, STENOD, LMR, MADMAN, Pick one and send them a car with a check for 75k and they will build you what you want....
You should know that currently the fastest LSX based drag radial car is running 7.80's... deep into the 7's is still uncharted territory.
ha ha. I laugh at the $75K comment
Ya better cut a check closer to $100-125K.......
esp if there doing all the labor
I see close to $20K for the motor
$10K for the turbo kit
$4500 for dry sump
$3K rearend
$4K trans
$3K converter
$7500 cage if not more for 25.2
BS3 $2500
Suspension $5K+
brake $1800
fuel system $4K+
labor $20K if not more
plus wheels, wiring, cutting fabricating and what not
plus all the money spent on fuel and track time tonget the suspension dialed in
It adds up fast.....
I'm sure I missed alot.
Kyle
$4500 for dry sump
$3K rearend
$4K trans
$3K converter
BS3 $2500
Suspension $5K+
brake $1800
fuel system $4K+
Kyle
Administrator
think anyone can quote you a price.
I am sure thats what u have in your roller but that dont mean you didnt pay too much for your stuff and the work you had done. I got 2 quotes from 2 diffrent chassis builders and they were both wayyy cheaper than the $19,000 you were looking to get. I didnt see your car on here or racing junk anymore did you sell it or decide to finish it? either way good luck it is a nice car.
Thanks for the input so far i guess i schould of made my post a little clearer, basically im only looking for a engine builder that does alot of turbo motors. car chassis , wiring all that stuff is handled just looking for some input on engine builders and what cost is to build a engine like this. i know it can very from state to state just trying to get a good average. Thanks in advance.
