QMP kit w/67mm,Mustang dyno=500rwhp.
Old 04-09-2008, 11:20 PM
SPRAYED 01's Avatar
Default Video inside.QMP kit w/67mm,Mustang dyno=500rwhp.
Finally got my new setup tuned at Straightline Performance. This is the old Rob Raymer QMP kit with a small 67mm turbo. I got rid of the small intercooler for a monster FMIC.
Unlocked 3k stall,9inch with 370 gears on a mustang dyno and it pulled 500rwhp and 480ftlbs. Im hoping for high tens on stock weight.
http://video.google.com/videoplay?do...56278424625687
Here is a little walk around of the car after the FMIC install. Dont mind the charger in the middle,and finally my two runs. First to 6k 2nd to 7k.
Alex
Old 04-10-2008, 08:09 AM
SPRAYED 01's Avatar
Video added
Old 04-10-2008, 10:18 AM
chewy99ws6's Avatar
Very nice, how much boost where you running?
Old 04-10-2008, 10:34 AM
SPRAYED 01's Avatar
Max boost was 13.5. Came on really quick and started to drop right at around 6700-6800rpm. Im thinking a 76mm would work out really well with this engine.
Old 04-10-2008, 10:46 AM
RW99's Avatar
Nice. I'm impressed that you were able to get up to 13.5 psi without maxing out the turbo; what's the A/R on that 67? And what's the heads/cam setup?
Old 04-10-2008, 11:12 AM
ninetres's Avatar
Sounded like he maxed it out to me if boost began to drop
Old 04-10-2008, 11:49 AM
SPRAYED 01's Avatar
Im not sure of the a/r on the turbo. I bought the kit used and didnt even check. Ill have it in the air tomorrow. The heads are ported/polished 241s,cam is a 226-228,.600/.609 lift on a 115+4 lsa.
RW99, What boost level are you running?
Old 04-10-2008, 11:59 AM
6 Second Club Moderator
LASTLS1's Avatar
Nice! It should kick some butt.
Old 04-10-2008, 01:12 PM
SPRAYED 01's Avatar
I hope so. Ill be at gld for slick night on the 17th. My goal is high to mid tens.
Old 04-10-2008, 01:47 PM
MIGHTYMOUSE's Avatar
keep an eye on exhaust backpressure
I would also relocate the wastegate to between the cylinder banks (unless it has all ready been moved to there)
if not that should fix your boost drop for a while anyways.
Old 04-10-2008, 02:20 PM
SStolen's Avatar
Exhaust housing = .96 a/r
Old 04-10-2008, 02:29 PM
SPRAYED 01's Avatar
Whats up Mike. Forgot to text you with the numbers. Everything went fine this time on the dyno. Only problem with it now is a small exhaust leak from a small crack developing of the rear primary.
Old 04-10-2008, 02:30 PM
SPRAYED 01's Avatar
MIGHTYMOUSE, Ive heard that helps out. This was just a beginner kit for me. I think im going to run it the way it is for a little while and then just swap out for a more high hp kit. Ive been looking at OFI or Kentucky Turbo kits.
Old 04-10-2008, 10:46 PM
GoatChzLS1's Avatar
Nice Alex! Lookin forward to seeing it.
Old 04-10-2008, 10:49 PM
Sideways240sx's Avatar
will you be at rsd's? im going to try to make it to all of them. We should meet up.
Chris
Old 04-11-2008, 08:01 AM
SPRAYED 01's Avatar
I try to go to as many rsds as possible. Slick night works with my schedule being on thursday nights. When is the next rsd
Old 04-19-2008, 06:59 PM
Rob_Raymer's Avatar
Thumbs up
Congrats on the numbers! Is that Mike Wells old kit?? (just curious)
As far as backpressure, that's not gonna be an issue. Especially with the .96 ar housing. And the wg location is also exactly where you want it to be...after all 8 cylinders. I made 790rwhp with the EXACT same wg location, on the exact same log manifold, but with a T-76.
Let me know if you I can help you with anything...
Old 04-19-2008, 07:04 PM
Rob_Raymer's Avatar
Duh...obviously it was Mike's. Just realized he was the one that posted the ar size.
Been a long week....
Old 04-19-2008, 07:38 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Not bad Alex, post up a whole slip and your raceweight. Are the GLD scales working? We should go up one nite, you me and Jimmy P we are like the only LS1 guys from the North side of Chicago. Formula is ready. Camaro is about ready too.
Old 04-19-2008, 07:51 PM
RW99's Avatar
I see 11.0 - 11.5 psi on the street. My T67 exhaust housing is 0.96 A/R, like yours.
Quick Reply: QMP kit w/67mm,Mustang dyno=500rwhp.
