Intake manifold and map sensor
Old 04-11-2008, 07:46 PM
CuNfUzEd's Avatar
Default Intake manifold and map sensor
A friend of mine has a sheetmetal intake. In the back where the map sensor is plugged in, the hole is over sized. He plans to run at least 15 #'s of boost and doesn't (for some weird reason) want it to push back out.
Do any of you guys have any suggestions on how to make it work? It is quite a bit larger.Thanks.
Scott
Old 04-12-2008, 05:14 PM
DuronClocker's Avatar
I was planning on drilling/tapping/epoxying that hole for a 1/8" NPT hose barb fitting and running a vacuum line to the 2-bar MAP sensor.
Old 04-16-2008, 11:55 AM
rudyzturbota's Avatar
so all i would have to do is use a vacumme hose going from my intake to the niple on the map.
Old 04-16-2008, 01:28 PM
DanZ28's Avatar
Yes, thats how I've seen them done and how I'm doing mine.
