Will I want to get new springs?
In two weeks I am going to be putting a rear mount turbo system on my 2k ws6. It has 70k on the clock and I was just wondering if it is necessary to put new springs on the heads. And if so, what springs? 918's or something? This turbo will only be running 5 to 6 psi tops for now. Also, at that boost with the high compression is it necessary to use an intercooler? FYI i have searched and found answers to all of my other questions so far.
Thanks in advance
Justin
Thanks in advance
Justin
im putting in an sts turbo in my car and i just started upgrading the valve springs to 918 because i was told anything higher than 5psi of boost on stock springs will give you valve float
Definitely a good idea to do springs, 918's would be cool. When i got my springs, the patriot dual's were not that much more than the 918's, but that was on a sponsor sale, but its something to look into!
As far as the intercooler goes, you definitely would be safer to run one, or as stated you could run a meth/water kit, as both would lower your IAT's. Also this boost stuff is / can get addicting, so you will probably want to run more and thats when the IC / better springs might be more beneficial down the road.
Good luck on the install!
My $.02
Thanks...
--Mike
My $.02
Thanks...
--Mike
^ Thanks for the info dcvingv6. I think i am going to go with the 918's so i don't have to deal with twin springs and price. I am going to intercool now too.
"Also this boost stuff is / can get addicting, so you will probably want to run more and thats when the IC / better springs might be more beneficial down the road."
You are most definalty correct in assuming that.
Hope this helps!
Thanks...
--Mike
