Will a D1 procharger run on an LS1
Old 04-15-2008, 08:18 AM
94lt1m6's Avatar
Default Will a D1 procharger run on an LS1
This may be a completly stupid question, and im pretty sure the answer is yes but im not positive. I am buying a D1 procharger from a member on this board, and he had it running on a carbuerated SBC. If i swap the Carb hat for a fitting for the LS1 TB would that work? If not its no big deal just wondering.
Old 04-15-2008, 08:19 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
make sure it is a reverse rotation unit...
Old 04-15-2008, 04:17 PM
94lt1m6's Avatar
How can you tell? it is a prochargerd D1. https://ls1tech.com/forums/non-lsx-parts-sale/899614-ati-d1-procharger.html that is a link to the add.
Old 04-15-2008, 05:41 PM
forcd ind's Avatar
is it a d1, or d1sc-take the serial # and call procharger
Old 04-16-2008, 04:34 AM
EPP
EPP's Avatar
This might help you out. Bob
Old 04-16-2008, 08:25 PM
Steve01SS's Avatar
Simple answer NO, not gonna work. That is a D1, NOT a D1SC. It's more similar to a P600B as far as mounting. Different bracket. Not the same as a P1SC/D1SC. It's also the wrong rotation. Thats a standard, not a reverse. It's also not self contained, uses oil feed lines.
Quick Reply: Will a D1 procharger run on an LS1
