Will 6 Bolt Heads Work On 4 Bolt Block?
Old 04-15-2008, 11:56 AM
SLID's Avatar
Default Will 6 Bolt Heads Work On 4 Bolt Block?
My heads are going to have to be replaced, I would like to build a LSX with the 6 bolt pattern on the heads later on. Will a set of LSX 6 bolt heads work on my 6.0L Iron block I have now? If it will I will go with them so I will not have to buy the heads later.
Old 04-15-2008, 12:12 PM
qqwqeqwrqwqtq's Avatar
LSX 6-bolt will work
Old 04-15-2008, 12:23 PM
ABeasst's Avatar
yes I was gonna get 6-bolt LSX heads and run them on a LQ9 block and ETP said it wouldnt be a problem.
Old 04-15-2008, 12:37 PM
charlie c5's Avatar
Yeah they will work. But the price for for WarHawk and the LSX 6-bolt block is getting pretty inexpensive.
Old 04-15-2008, 12:51 PM
Dumb Ass Vette Moderator
ls1290's Avatar
I agree. Isn't the LSX block around $1800?
Keith
Old 04-16-2008, 08:51 PM
SLID's Avatar
Do any of you guys know off hand which heads would have the thickest deck on them. AFR, Dart, ETP, Trick Flow or any others.
Old 04-16-2008, 09:56 PM
52172's Avatar
answer is yes
Old 04-17-2008, 11:25 AM
ABeasst's Avatar
I'd be interested in this also.
Old 04-17-2008, 12:00 PM
If you're going to buy 6-bolt heads for an LSX block I think your only options at this point are ET and All-pro.
Old 04-17-2008, 07:26 PM
GrannySShifting's Avatar
ET or Allpro. I know the ET deck is god bit thicker most all the other castings.
Quick Reply: Will 6 Bolt Heads Work On 4 Bolt Block?
