new set up, what gap to go with?
Old 04-21-2008, 09:49 PM
kbraklr's Avatar
Default new set up, what gap to go with?
what should i gap my spark plugs to? NGK TR6's
new setup (not yet installed, lol):
Ported lq9 heads
ls6 cam
custom 76mm turbo kit
stock bottom end
9 lbs boost...
what gap?
any hp estimate? im hoping about 550 rwhp, since my car runs like a freak anyways...
Old 04-21-2008, 10:16 PM
kbraklr's Avatar
bump....
Old 04-21-2008, 11:15 PM
kbraklr's Avatar
any guidance would be appreciated..
Old 04-21-2008, 11:21 PM
BigBlockCamaro's Avatar
.30-.35 with tr6's
Old 04-21-2008, 11:22 PM
if you dont hit 550... SEND THE PRODUCTS BACK....that should be a low mark for you on 9psi
Old 04-22-2008, 12:02 AM
kbraklr's Avatar
Originally Posted by BigBlockCamaro
.30-.35 with tr6's
thank you kind sir!
Old 04-22-2008, 03:52 PM
Anytime brother!
Old 04-22-2008, 04:12 PM
Photochop's Avatar
No kidding, M6 I'm guessing? I'd be real pissed if you don't hit 600 honestly on 9 psi. Make sure your tune is dead-on, 9 lbs on a stock bottom is pushing it. You're creating alot of cylinder pressure for stock pistons/rings with that much boost. I think you'll hit your 550 goal with 5-7 lbs (depending on how efficient the kit is) and be easier on the motor.
Old 04-22-2008, 04:28 PM
MECHAM's Avatar
i would leave it gapped at whatever it comes out of the box
Old 04-23-2008, 02:23 AM
kbraklr's Avatar
its lower compression now, with the lq9 heads. 9lbs will be fine...
Quick Reply: new set up, what gap to go with?
