Quick truck coil question
Old 04-23-2008, 12:35 PM
ninetres's Avatar
Default Quick truck coil question
I read in a thread that the harness is different. Is this true? I know I need the bracket and MSD truck wires.....but will my 2001 camaro harness still plug in?
TIA
Old 04-23-2008, 01:13 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Plugs right in.
Old 04-23-2008, 04:26 PM
tomz28's Avatar
i have a 2000 camaro and some 01 truck coils they are not the same you need the truck harness but are the 01s the same as the truck i would like to know as well thanks
Old 04-23-2008, 07:54 PM
2002_Z28_Six_Speed's Avatar
The brackets are different.
Old 04-23-2008, 08:02 PM
ninetres's Avatar
dur dur dur. Thanks, but I mentioned that in the first post. So far we have differing opinions on whether or not the harnesses are plug and play. I think I am leaning with PSJ's advise......don't know why
Old 04-24-2008, 10:27 AM
Fireball's Avatar
There is a "mini-harness" that goes from the big connector on your main engine harness to the individual coils themselves. That harness is different. F-body "mini-harness" won't plug into the coils...need a truck "mini-harness" The big connector that connects to the engine harness is the same on both.
Old 04-24-2008, 02:39 PM
xssive's Avatar
Correct, the main harness plug will hook up the to factory wiring, but the individual coil plugs are different. You need the truck coil harnesses with the coils
Old 04-24-2008, 11:42 PM
ninetres's Avatar
Part number?
Old 04-25-2008, 03:06 AM
xxxhp's Avatar
Part number?
http://forums.corvetteforum.com/show....php?t=1967469
Old 04-25-2008, 09:49 AM
LS1Tech Co-Founder
Right you need the coil mini-harness.
Old 04-27-2008, 06:45 PM
ninetres's Avatar
Do you need two of them right? Or no? Thanks for all the help so far guys. I need it
Old 04-27-2008, 06:51 PM
xssive's Avatar
Yes you need two of them
